Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Strange Engine Cutout when on freeway??
    Dec 2017
    NE Melbourne
    So I cleaned the MAF sensor - have only driven it twice since then and I'm not sure if I am imagining it or not but it seems to be more responsive when accelerating (noting that I am only driving within 5 km of home at this stage due to lockdown in Melbourne!!!
    I also have a new intercooler on order from ARE (thanks for the heads up Pollenface) that will get sent down to me next week once they are back from holidays......looking forward to getting it fitted to see if it sorts things out!!
    Legendary happygu's Avatar
    I second the ARE Intercooler. Mine has been excellent, but I have only tried the one, and there are bigger and better.... I just kept away from the Cheap Chinese Ebay ones, as from my research, some of the alloy used for the end tanks was of a very poor quality.
    Mine still looks factory, with a tiny modification to the Engine Cover.
    Have you tried bumping the Chip back a notch or two ..... I was looking at these chips back in the day when they were available and I remember others noting that if they pushed the chip tune too hard that they noticed similar engine shutdowns
  4. The Following User Says Thank You to happygu For This Useful Post:
    Big Gags (14th August 2020)
  5. #13
    465 Post(s)
    Get a scoop like this. As I said the OEM scoop is next to useless. I saw lower EGTs once this was fitted. It catches a heap more air than the waste of space OEM unit.
  6. #14
    Dec 2017
    NE Melbourne
    Quote Originally Posted by happygu View Post
    I did that too - knocked it back to 5 again on the chip.....guess the real test will be once lockdown is over and I'm allowed to tow the boat again!!
  7. #15
    Dec 2017
    NE Melbourne
    I'm considering one of these too but it might be down the track a bit - I was looking at the ARE Stealth Scoop for $588 but it apparently comes in matt black and so unless I want the GU to look a bit like an XY Falcon I will have to also factor in more cost to get it painted to match the silver paint!!
    How much difference did you notice when you fitted the bigger scoop?
  8. #16
    465 Post(s)
    Quote Originally Posted by Big Gags View Post
    EGT's dropped by 50c. Really noticed it when your screaming up a hill and the EGT's start to go up and then you hit the top and coast over they dropped really fast. Well worth it in my opinion. The scoop pictured was from A.R.E Cooling. Not sure if they still do them, that was quite a while ago, and no one else did them. I know you can buy them a lot cheaper these days though. As long as it fits the factory spot your good.
  9. #17
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Yep they do here for $588.
    Another one here for $175
  10. The Following User Says Thank You to Brissieboy For This Useful Post:
    Mickhead (25th August 2020)
  11. #18
    Dec 2017
    NE Melbourne
    So I got the new ARE Intercooler in, the MAF Sensor is clean, and I have wound the TuneIt chip back down to 5.......seems OK for the short bit of running around that I have done within 5 km of home but I guess time will tell when we are allowed to go fishing again and I get to hook the boat up!!! Thanks for the advice guys.
