Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Front lockers in a Gq Pro and Cons ?
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    @mudrunner Nothing to do with a locker. If the going gets very tight, putting the transfer lever into 2wd gives tighter steering than 4wd with hubs locked. (ie. no need to get out of car to unlock hubs). Try it.
    Yep for sure. The 79 series troopies turn better if you unlock the hubs too. Stupid work policy means they're locked in all the time.. I unlock them so I can manage a u-turn without it becoming a 3 pointer. No idea on the physics, but same road, same inputs, different turning circle.
    474 Post(s)
    Selectable (when driver chosen) front lockers for the win @First Pooy Mate!
    ‘Most’ of our Trols rear LSD’s are as tight as a Nun’s..... and very near rear locked capable from stock for 90% of adventures.
    Haven’t personally had experience in my twucks with front auto type lockers but do watch mates struggle with them up and down tight rocky tracks putting their panels way off track especially on hairpin turns etc...
    Very early designed auto lockers also used to get confused in creek crossings with slippery boulders and go pop poop stranded too :-(
  4. The Following 2 Users Say Thank You to MB For This Useful Post:
    First Pooy (7th July 2020), PeeBee (22nd June 2020)
  5. #13
    Jul 2020
    mechanical only way to go
