Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: Old patrol roof rust repairs
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    Best post I've seen on here in a long time.great looking work too.
    Keep up the updates mate
    Sep 2019
    New Zealand
    4 Post(s)
    Q&A
    Figured I would answer some of the questions you guys are asking...
    I left the seats in because they are already rather tired/stained/ratty so I'm not worried about the odd burn mark (and I don't currently have anywhere else to put them)
    I am however protecting the interior from weld splatter as best I can using a mixture of wet old bedsheets and spare steel panels that I wedge between what I'm welding and the interior.
    I'm using the side panels from some server racks that we decommissioned at work as the donor steel. It's the right thickness and I have a pile of them.
    I'm hand shaping the steel at the moment - lacking a sheet metal bender I'm afraid. The usual process is to clamp the steel to a large chunk of angle iron, then bash it with a hammer until it looks about right.
    A donor car would be handy to chop bits out of, however finding one without any rust in the roof would be tricky. All the patrols I have seen at wreckers have visible rust in the roof area, and even if I find one without visible rust, I won't know its condition until I haul it home and yank the roof skin off. At this juncture, I think it's a better/easier option to just fix the rust in what I've got.
    At this point it's unfortunately a slow project. I can only really work on it during the day on weekends, when it's not raining, and at reasonable times so I don't drive my neighbours insane with the dulcet tones of air compressors, saws and grinders.
  4. The Following 3 Users Say Thank You to Nhoward For This Useful Post:
    Cremulator (19th March 2020), mudnut (23rd March 2020), MudRunnerTD (19th March 2020)
  5. #13
    Sep 2019
    New Zealand
    4 Post(s)
    slowly slowly...
    Got some more done:
    Cleaned up this bit where the frame had rusted out:
    Chopped a rusty bit out of the B-Pillar:
    measured up and chopped off a piece of server panel that had a convenient 100* bend in it and tacked it in to place:
    Started welding it up. Doing a little bit at a time so that nothing gets too badly warped:
    Finished welding and started grinding:
    Gave it a shot of primer:
    On to that hole in the B-pillar.
    One CAD template transferred to steel:
    Chopped out and ground the paint off the edges:
    Apply some dodgy bending methodology:
    Tack it in place:
    Finesse it with a large hammer, and weld it in:
    Go nuts with the flap disk:
    Not bad for a Saturday afternoon. Once piece at a time.
    With the country going in to covid19 lockdown on Wednesday, the upside may well be more time to work on this thing!
  6. The Following 7 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (24th March 2020), Cremulator (24th March 2020), MB TD42 (23rd March 2020), mudnut (23rd March 2020), PeeBee (24th March 2020), Sherro (10th May 2020), Touses (24th March 2020)
  7. #14
    Sep 2019
    New Zealand
    4 Post(s)
    A little more progress
    I'm trying to be nice to the neighbors during lockdown, so I have not been working on the Patrol much.
    I have made a bit of progress though;
    A couple of patches coated in weld-thru primer drying in the sun:
    Tacked in:
    Welding up:
    Welded up:
    Flatteneing off:
    Then rinse and repeat with another patch:
    At this point I was rapidly running out of daylight so I called it a night.
    Progress is still slow, but the driver's side of the truck is now more metal than rust and air.
  8. The Following 8 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (12th April 2020), Cremulator (11th April 2020), mudnut (11th April 2020), MudRunnerTD (22nd February 2021), PeeBee (11th April 2020), Plasnart (11th April 2020), Rossco (11th April 2020), Sherro (12th April 2020)
  9. #15
    Sep 2019
    New Zealand
    4 Post(s)
    A short update...
    between the covid lockdown and a few weeks of bad weather I have not managed to get too much done, but I have made some progress;
    Chopped out a big chunk around the B-pillar:
    cut out and bent up some patch plates:
    Spent an afternoon playing metal tetris:
    Got it all welded in (and most of it ground back & painted):
    On to the next problem... quite a bit of rust on the A-pillar:
    A problem easily solved with the air body saw...
    That did leave quite a bit, oddly shaped hole though
    For my next challenge, I need to make the piece on the left look like the one on the right (minus the rust):
    While I was tearing some of that apart it did make me wonder - do any of you lot know why the roof skin and gutters are brazed on at the corners?
    I'm hoping it was done for ease/speed of assembly but I'm not 100% sure.
  10. The Following 4 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (11th May 2020), Plasnart (12th May 2020), Rossco (11th May 2020), Sherro (10th May 2020)
  11. #16
    Sep 2019
    New Zealand
    4 Post(s)
    Right... time to something about that hole...
    Use some paper to make a template, then trace the result on to some steel:
    Cut it out, stuck it in a bender then bash it with a hammer (or 3):
    Sand it back and drill some holes in it for plug welds (I did paint the back of it with weld-thru primer):
    Weld in the plug welds, tack some of it place then align it to final shape by bashing it with a hammer some more:
    Weld it up, then grind it back:
    Give it a coat of weld-thru primer:
    Got this other patch tacked in, then ran out of daylight:
    I'm getting tantalizingly close to finishing off this frame rail.
  12. The Following 8 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (13th May 2020), Cremulator (11th May 2020), jack (11th May 2020), mudnut (11th May 2020), MudRunnerTD (22nd February 2021), PeeBee (11th May 2020), Plasnart (12th May 2020), Rossco (11th May 2020)
  13. #17
    193 Post(s)
    Love your work mate keep it com'n. She's looking good can't wait to see how it comes up
  14. #18
    109 Post(s)
    Yep this is a bloody tops thread. Loving it @Nhoward Brilliant work so far mate, keep it going.
  15. #19
    You have the patience of a saint. Top work.
  16. #20
    Jul 2017
    Bundanoon, NSW
    I love your work, I am so limited in what I can do in my workshop at the moment due to all the joeys in care...can't even finish putting the engine back together.
    Great to see someone repairing rather than just throwing away a lovely old truck.
    It's amazing how much time we don't have when in quarantine (not that it changed anything for us, if anything we go out more. sigh)
    Greg Pointing
    Conservation, Rehabilitation & Education
    1989 GQ Patrol Wagon, TB42 Auto - Now with 2" of added lift...
    1991 Mazda MX5 - Coilovers, Exhaust, Intake, NB brakes & seats.
    2012 Mitsubishi Triton 4x4 Dual cab TDI - The Mrs truck....
