Page 943 of 1057 FirstFirst ... 941942943944945 ... LastLast
Results 9,421 to 9,430 of 10566
  1. #9421
    Advanced tryan277's Avatar
    May 2016
    Melbourne, Southern Burbs
    Pulled one of my FW Hubs apart today (thanks to mudski on how they come apart)
    A bit grotty inside where the spring is.
    A bit cleaner now.
    One question, is it worth while getting the circlip out that can be seen in the second last photo to totally dismantle the hub?
    Cheers Trevor
  2. The Following User Says Thank You to tryan277 For This Useful Post:
    10G (18th March 2020)
  3. #9422
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    New spark for the old girl today. Bought from a small town garage for $30 less than that super "cheap" place sells them for. Pays to #buyfromthebush.
    Sent from my campfire using smoke signals.
  4. The Following 2 Users Say Thank You to VK2FMIA For This Useful Post:
    10G (24th March 2020), mudski (24th March 2020)
  5. #9423
    Quote Originally Posted by tryan277 View Post
    A bit cleaner now.
    Cheers Trevor
    I did. Its quite easy. There is a square oring that goes around the plastic part that you turn to lock the hubs, so try to avoid using and petrol or the likes to clean the hub up as you will destroy the oring.
    Yours looks pretty clean. I just regreased in there to help stop water ingress...
  6. #9424
    Jun 2018
    25 Post(s)
    Not to the Patrol, but made some jumper cables for it, as I didn't have a set.
    3 gauge / 25.72mm˛ I think it is, 5 metres long.
  7. The Following 5 Users Say Thank You to Cremulator For This Useful Post:
    Hodge (25th March 2020), jay see (25th March 2020), mudnut (25th March 2020), mudski (25th March 2020), Yeti's Beast (25th March 2020)
  8. #9425
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Looks like reasonably decent clips too. Most of the ones available these days are almost paper thin.
  9. The Following User Says Thank You to Brissieboy For This Useful Post:
    Cremulator (25th March 2020)
  10. #9426
    Jun 2018
    25 Post(s)
    Quote Originally Posted by Brissieboy View Post
    Yeh they have a decent spring and solid jaws.
  11. #9427
    Saw that Repco had 50% off on all maxitrack a few days ago and I needed a new UHF cable. Instead I brought this for $35.
  12. The Following 2 Users Say Thank You to jay see For This Useful Post:
    mudnut (28th March 2020), rusty_nail (28th March 2020)
  13. #9428
    Fitted the above aerial.
    While pulling out the old cable the radio went out, that gave me another job to do. Out with the radio to find the disconnected wire. Wasn't to bad, now setting it all back to how it was is going to take even longer.
  14. #9429
    May 2016
    lower west victoria
    30 Post(s)
    Some radios stop when you disconnect the areal cable, I reckon it's an earthing thing.
  15. #9430
    482 Post(s)
    Refueled another 250L under tray via 24/7 unmanned tap & go go zero contact, albeit Glen 20 is my new Bushman’s first response handle squirt
  16. The Following 2 Users Say Thank You to MB For This Useful Post:
    Rossco (5th April 2020), Yeti's Beast (11th April 2020)
