Results 1 to 7 of 7
Thread: Ring Gear. To flip or not to flip.
    G'day, All. I have obtained a secondhand flywheel for the RB30 but the ring gear is a little chewed up. I haven't found a new one anywhere. And Nissan don't stock them. The engine mob who I might get to machine the flywheel said they could flip the ring gear, but is it a good solution, or not?
    465 Post(s)
    not unheard of to do it. I remember flipping the ring gear on my old 308, and 350 in my Panelvans back in the day.
    They are still available though genuine. Should be circa $160 with freight to you.
    mudnut (20th March 2020)
    Sorry to be spoon fed, Mark, but where from? The local Nissan dealer say they haven't got a listing for it. Patrolapart say no. Internet thingy says no.
    465 Post(s)
    No probs mate.
    Then put the part number into here....
    https://www.amayama.com/en
    As this mob is based in Sydney...
    If you PM your VIN I can double check the part number but as far as I know, or would think, all RB30 ring gears would be the same. Did Nissan give you a part number when you asked them?
  8. #5
    Onya, Mark. No part number listed. I'll have a go at getting one, cheers.
  9. #6
    465 Post(s)
    Shoot me your VIN Craig. I have the Nissan Parts program on my laptop. I can look into this for you if you like.
  11. #7
    Jan 2017
    Hi I had a worn ring gear on an MGB years ago. It was beveled on one side only so could not flip. However the main wear was in two opposite sections. I put the whole thing in the fridge for a day, got everything ready. Then took it out , hit the ring gear with a lpg gas torch and it dropped of [ dont forget to mark it first with a punch, before even putting in fridge ] , turned the ring gear 1/4 turn and while the flywheel is still cold keep heat up to ring and drop it back on, give a few taps with hammer for good luck.
  12. The Following User Says Thank You to Dagwill For This Useful Post:
    mudnut (22nd March 2020)
