Results 1 to 7 of 7
Thread: Gq wabbles
    Expert First Pooy's Avatar
    Mar 2018
    Gq wabbles
    Gq wabbles what are they and when do the occure like at what speeds and the feel of it ?
    If your refering to "death wobbles" usually the sweet spot is around 80k's but not always. Usually need a little bump to set it off then just builds till it's quite violent with the wheel shaking fron one side to the other and the car shaking like buggery. . Once it happens you'll know about it lol, they're a bugger that's 4 sure. .
    Just imagine your steering wheel shaking when you need to get your wheels balanced..... but 50 times worse. Mine have happened anywhere between 60-100kph. First time was bearings, 2nd time was panhard bar bushes. Third time was due to the passenger side crappy GQ hub nut coming loose.
    Maybe worse with a chunky mud pattern tyre
  5. #5
    Mar 2018
    Thanks for the response guys I didn't known that the Gq wabbles meant a death wabbles I had that before and I defiantly know what it is, oh well back to the drawing board I have vibrations at high speed not voilant like in a death wabbles but vary annoying but I have changed a heap of stuff over and yesterday I balanced all four wheels plus an alignment and it feels like crap
  6. #6
    Quote Originally Posted by First Pooy View Post
    How high is high speed, how did they balance your tyres, did they use fingers through the wheel stud holes?
    Is vibration coming through the steering wheel or through the car?
  7. #7
    Mar 2018
    Between 100-110 and I balanced the sunnys myself and the vibrations was through car and wheel, but I have worked most of the problems out my diff was out of alignment causing drive line vibrations and the tyres have had it, one fell apart when I was debeeding it so I had to put the spare on and suddenly nearly all the problems were gone
