Results 1 to 7 of 7
Thread: Hot wire IP , so im sure if its IP or electrics ??
Threaded View
  1. #7
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by Dagwill View Post
    Just disconnected the fuel return line from IP. Ign. key OFF and hand pumped primer , I get a dribble of about 3 drops per second. Ign key ON still get a dribble about 3 drops per second.
    Any thoughts please
    My thoughts are that probably none of it will operate like it should unless the car is running. I wouldn't expect fuel to be pouring out of the return as it sits.
    Seriously mate if you don't believe the codes take it to someone to have a look at it. If the pump is indeed gone to the gods they'll tell you quick smart.
  2. The Following 2 Users Say Thank You to 0-TJ-0 For This Useful Post:
    Dagwill (5th July 2019), mudski (6th July 2019)
