Results 1 to 5 of 5
Thread: JT Cooler Induction Noise (H/Flow under load) - Game changer
Threaded View
  1. #5
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Don’t t quote me on it but I do think that the welder from CC left and went out on his own. JT sounds familiar. And yeah. You should sit in my Patrol and have a listen. 30psi of rushing air drones out the 4inch snorkel induction noise by a lot.
    Sent from my crapPhone using Tapatalk
    The owner of Jonny Tig Industries (Jon) did weld and was heavily involved in CC. Has moved on and doing some good work.
    Induction cold side, especially 4" snorkel drawing away would play with the sound mix. Have noted that my induction is a lot quieter with the JT cooler than when I was using the ADRAD stock size cooler, maybe due to less vacuum on cold side of turbo as the JT cooler has high flow attributes. Do not hear the same level turbo spool song, even doing muffler delete and w/muffler back to back comparo. Run 76mm induction might look at doing a JT 4" airbox and SS snorkel. Maybe a new stereo, I want one..
  2. The Following User Says Thank You to Bidja For This Useful Post:
    mudski (25th September 2018)
