Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 92
Thread: Build time
  1. #61
    Yeah nice sure it will come up awesome and should be fun, enjoy. . .
  2. #62
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    So the series of photos I am about to upload are from the crankshaft. 5 of them are fine one is not. I’ll let you guess which one
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
  3. #63
    Dec 2016
  4. #64
    Dec 2016
    There is some surface contaminants on the others from being in the garage for a while but the damaged one I just took out.
  5. #65
    Ooh ouch. . .
  6. #66
    Dec 2016
    The good one
    The shit one
  7. #67
    Dec 2016
    Do you think they could save the crank shaft? Polish it out
  8. #68
    Yeah bugger bet your glad it's getting a rebuild now. Had the bearing spun on the journal or just buggered? Expect it's a result of low oil or lack of oil changes most likely ? ? Looks fairly substantial, machine shop will know once it's measured or might have to be ground to see how much needs to be taken off to get it good again. Not sure what over size the bearings go up to will determine the repaiability.
  9. The Following User Says Thank You to Rossco For This Useful Post:
    JackCollo (25th March 2018)
  10. #69
    Dec 2016
    Build time
    I think that some debris or something had gotten into the motor and in the journal because they were in the right spot.
    Yeah hopefully it can be repaired
    Will I need o/s or u/s Conrod bearings?
  11. #70
    Dec 2016
    Build time
    Has anyone had any dealings with crankshaft rebuilders in Blackburn thinking about giving them a call but didn’t wanna waste my time. Open to all opinions.
