Results 11 to 20 of 24
Thread: TB42 to TD42 - Tacho Not Working.
    Jun 2014
    iran
    hi sir
    thank for your answer
    i was do all you say sir
    run a wire from the tacho sensor ( it is end of gearbox 2 wire green and yellow yes ???) into the instrument cluster and connect it into pin 11. i do this part -
    you say ::you will just need to extend it from where the coil was to the tacho sensor.
    where is that sir ?
    what i most to do and forgot sir ?
    Sep 2017
    Nowra
    can someone confirm exactly what needs to be done to get tacho working?
  4. The Following User Says Thank You to BrodieTiGQ For This Useful Post:
    MB (25th March 2018)
  5. #13
    475 Post(s)
    Two Bulls once entered a ring, headstrong yet truly tired each Brodie mate! The answer you seek may well only be answered by ExtraTerrestials maybe these days mate, and or until they agree to disagree for the good of y’all;-)
  6. #14
    Sep 2017
    Nowra
    uhh?
    I don't know what that means
  7. #15
    475 Post(s)
    Apologies Brodie mate, Sunday session, my bad :-( !
  8. #16
    Sep 2017
    Nowra
    haha so can you help with my question?
  9. #17
    475 Post(s)
    @Yendor mate?
  10. #18
    Quote Originally Posted by BrodieTiGQ View Post
    the wires that come from the timing cover meet at the top of motor to a clip,on mine I found that the wires inside the clip were brokenthe clip or wire joiner was just at the top of motor near the thermostat.,soldered em up and it worked till the day I sold it
  11. #19
    Sep 2017
    Nowra
    sorry I should of mentioned in my case I've done a motor and gear box swap from tb42e automatic to td42 manual and am using the tb42e wiring loom
  12. #20
    193 Post(s)
    Hey mate mine is a conversion using the old tb loom as well. From memory the wire goes strait from the engine speed sensor to the back of the cluster. There are two wires tho can't remember where the other one goes could have a look @ the wiring diagram or give Patrolalart a call they did mine. Chappy also did it and is in his build thread somewhere.
