15th March 2018, 07:36 PM
Tips/help with egr plate
I know there is alot of other posts about the egr plate but i couldnt find one to help me.
Ive seen on other posts about there being 2 bolts to loosen and then slide the plate down etc
Haynes booklet shows it as 2 bolts
Now the problem ive got is that there is 3 bolts (see attached pictured)
And upon loosening them off there was no movement on the housing therefore i was unable to slide the plate into place.
I gave it a few gentle taps with a persuasion bar but there was no persuading it to budge. Im guessing that just the constant heat over the years has made it tougher to move.
Am i doing something wrong?
Any tips or advice would be greatly appreciated.
CHEERS IN ADVANCE
15th March 2018 07:36 PM
15th March 2018, 08:19 PM
I am he, fear me
More persuasion required...
15th March 2018, 08:29 PM
the evil twin
I gave it a little
Was abit scared incase i cracked it somehow
So bit more weetbix you reckon?
15th March 2018, 08:50 PM
Is the plate you have to suit where you are showing? Usually the plate sold on Fleabay etc suit the cast EGR pipe where it bolts to the inlet manifold. Much easier there. Just remove the two bolts, get a long screw driver or similar and pry the pipe open just enough to slip out the gasket and in the plate.
16th March 2018, 05:31 AM
mudski
Yeh mudski the plate ive got suits that spot. See attached pic
Mate from work showed me the spot to install it.
Does it get installed where ive circled red or green. See pic attached.
18th March 2018, 07:42 PM
Green mate. I wont fit in the other spot.
