21st January 2018, 05:03 AM
Rear brakes replacement on Y61
Please can someone advise me on how to go about doing this. Cannot find much help
21st January 2018 05:03 AM
28th January 2018, 10:35 AM
Hi Tank, are we just looking at pad and rotor replacements . this is what I used from Ebay with good Bendix 4X4 pads - easy to do regards Alex
Rear
https://www.ebay.com.au/itm/2-Rear-S...53.m1438.l2649
Front
https://www.ebay.com.au/itm/2-Front-....c100011.m1850
Use Youtube to show you how to change over - easy
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
5th February 2018, 12:52 PM
remove tyre
remove caliper
push piston back
new pads in
bleed
you tube is your best friend
