Results 1 to 8 of 8
Thread: AC Vent control !!
    May 2016
    8 Post(s)
    AC Vent control !!
    well what a right bugger of a thing !!!
    I have removed the radio and Console !
    removed the screws in the knob unit But cant get it out from the dash
    What am I missing ? I can see the cable that need some attention .but cant persuade the dam thing to come out .
    I am not enjoying the patrol experience ... GU 2005 4.2 turbo job . please Help !!!
    May 2016
    8 Post(s)
    well there has to be someone who has had one out somewhere surely
    177 Post(s)
    It should just come out mate.
    Remove radio surround and fascia .
    Remove the trim plastic from around the gear stick and i think its 2 screws from there it slides out.
    I may have photos from when i done mine. But im 12 hours from home and my car so ... cant help yet.
    Tip12345 (27th October 2017)
    May 2016
    8 Post(s)
    Thanks I will have another go . I have a control board for the transfer pump I think . I need to disconnect . I can't get the plug to work .... I can see a bent cable at the control end . I thought that after the clutch replacement it would be easy .. will have another go and get some pictures . Thanks to all
    May 2016
    8 Post(s)
    bump still stuck!!
    smash it with a fucking big hammer...you are one patient person i'll give ya that..
    May 2016
    8 Post(s)
    Yes I can see the dam bent cable but can I get the bugger of a thing out !!!
    I have done heaps of work on the beast from hell And this has to be the most frustrating thing so far .
    I cant get the electrical connection apart on the Tank relay box . and cant get the control out from behind the dash its loose . I am thinking of taking the glove box out next ...
    I am taking time off and fitting the 3" exhaust and new intercooler . I do all my own maintenance and the factory piece of crap has to go . After some time on the dyno with some temp sensors.
    I found it was just better than useless ! so in with an out front cooler . I just about have all the bits made .
    I almost always drop the glove box out when working up in that area... a few screws and 2 minutes and a lot less angst.
    The eleccy connector on the Sub Tank Computer is a PIA if you don't squeeze it in the right place to 'release' the lock.
    The vent controller is just a PIA
  10. The Following User Says Thank You to the evil twin For This Useful Post:
    Tip12345 (2nd February 2018)
