31st January 2018, 11:42 AM
Fan only working on "4"
Hi guys,
The A/C (and heater) fan is not working on the first three levels, but goes to full on level 4.
Any ideas? My thinking is that the motor is on it's way out and requires full voltage to start spinning?
31st January 2018 11:42 AM
31st January 2018, 11:44 AM
If it is a GQ, the resistor pack which is inserted into the air ducting will be shot. The resistor pack is positioned just under the glovebox, next to the fan housing. Either that or the switch is jiggered.
The Following User Says Thank You to mudnut For This Useful Post:
dom14 (4th February 2018)
31st January 2018, 12:05 PM
I am he, fear me
Wot mudnut said X 2
99.9% the Ballast Resistors have had the richard.
31st January 2018, 03:38 PM
yep,mine did the same in gu..resistor
31st January 2018, 05:57 PM
And another one here... Resistor pack underneath dead. Happened one my 2009 GU as well.
Under normal circumstances, #4 setting there is no resistance. Straight through Volts.
1, 2 and 3 are resisted to slow the fan down. Over time the pack becomes dry on the inside and becomes brittle. Some have had success with solder and bits from Jaycar. But for the cost of a new pack, it's not worth it.
31st January 2018, 05:58 PM
The Following 2 Users Say Thank You to Hodge For This Useful Post:
dom14 (4th February 2018), mudnut (31st January 2018)
2nd February 2018, 02:54 PM
Thanks guys, I shall check the resistor pack.
4th February 2018, 01:18 PM
#8
Mine's has similar issue. Number 1 is not working but 2,3.... ok. I haven't bothered to replace the resistor yet 'cos I rarely use the number 1 speed.
4th February 2018, 03:54 PM
#9
mudnut
Yeah, thanx for the tip with the switch. Mine actually can be a jiggered switch as well.
13th February 2018, 08:28 AM
#10
I managed to solder a bridge into the fusible link location on the resistor in my GU2, was still working years later when I traded it in.
Graham
