Results 1 to 10 of 12
Thread: Wiring loom replaced
    Jul 2016
    Hi just spent the best part of 3 days replacing the loom in my gq .
    Now i got to find where the engine immobilizer goes or what the old one looks like. I do have one that i removedbut cannot find any info about it. The last owner just put in a flashing diode.
    I did find the old central locking. Also i did install another one but need to wire it into my replacement loom.
    I was amazed that everything works except the rear wiper not working. It was not working before.
  2. The Following 2 Users Say Thank You to kbchez For This Useful Post:
    GQtdauto (13th January 2018), MB (12th January 2018)
    Legendary dom14's Avatar
    38 Post(s)
    What is the reason for wiring loom replacement?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Because his original one had a meltdown a while a go
  6. The Following User Says Thank You to Clunk For This Useful Post:
  7. #4
    to make a wig wam for a gooses bridle
  8. The Following User Says Thank You to Avo For This Useful Post:
  9. #5
    38 Post(s)
    Figuratively or literally? We're talking about OP's GQ's wiring loom, right?!
    Cheetah Outreach
  10. #6
    475 Post(s)
    Quote Originally Posted by kbchez View Post
    ......... Bump...........
  11. #7
    Jul 2016
    The old one had burnt wiring , fried, been like that for a while before i brought it. It was caused when the lpg was put in about 12yrs ago. The wiring loom was squarshed then finally melted burnt wires including high beam left side only. I traced the burnt wires to be hind the glove box and still could not find any good wires.
    When i was removing the loom i found more fried wires to the distributor. It wad worth the trouble.
    M
    Now the engine idles much better if not perfect.
    Still have speedo stopping issue, and trouble with the auto transmittion inhibitor.
    Now what immobilizer do i fit.
  12. The Following User Says Thank You to kbchez For This Useful Post:
    MB (13th January 2018)
  13. #8
    475 Post(s)
    @ Dom14 mate?
  14. #9
    38 Post(s)
    M
    Yeah, possibly as a result of a previous backyardie LPG conversion job.
    I had to learn the hard way to replace and fix 90% of the LPG wiring in mine.
    It was absolutely horrendous. 95% of LPG issues I was having were from bad electrical wiring, except having to replace the
    Impco model L converter which was way past it's use by time.
    Lucky, yours didn't end up as an insurance claim, 'cos they can be that bad in terms of cost of fixing.
    Last edited by dom14; 15th January 2018 at 09:32 PM. Reason: missing letters & grammar
    Cheetah Outreach
  15. #10
    38 Post(s)
    You may find out brand new wiring might save lot of time and headache than trying to locate and fix the old one.
    That's what I did with my fuel pump wring/relay related issues. Give direct power to the rear wiper to make sure it's not kaput, then
    start from the wiper switch an rewire it if that's easy.
    It may be easier to wire up a new immobilizer with central locking. They are fairly cheap if you wanna get a one from fleabay.
    Cheetah Outreach
