Results 21 to 30 of 32
Thread: Master cylinder no fluid
    Advanced my93maverick's Avatar
    Oct 2015
    Having no direct experience with your veh so info provided for thought.
    All this brown like gunk in the housing that where you are supporting the push rod, is it moisture ingress mixing with brake fluid? If so, it appears your master cyl piston is gone or maybe it is some old grease / moisture mix . The rod wobbling around is more than likely behaving that way as it provides a means for it to allign for assy and operation.
    Look, it is a bit hard to see bore condition but really it is probaly getting past it so might be easier and cheaper in the long run to buy that new master and slave cyl (trouble free for a while). What ever way you choose flush your lines with new fluid prior to hooking up to slave. Gunk and moisture is more than likely to be in the line.
    Awesome thanks heaps for all the info guys i do appreciate it as im a very novice mechanic, will put the new master on purchase and see how we go fingers crossed
    Sent from my CPH1701 using Tapatalk
  2. #22
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Quote Originally Posted by my93maverick View Post
    OK if only Master Cyl, still disconnect at line at slave cyl and flush the sys thru with new brake fluid very well and then hook up slave and bleed.
  3. #23
    84 Post(s)
    As above, but go ahead and use the air compress on the line when it is disconnected from both ends, then flush it out thoroughly with fluid before reconnecting it.
    my93maverick (12th December 2017)
  5. #24
    Jul 2017
    40 Post(s)
    Considering there appears to have been a blockage (more than likely though at m/cyl), but to prevent any crud at all that may be present in the actual line from plugging up with the force of the compressed air. It maybe safer to first attempt a flush thru with brake fluid using the m/cyl then air and back to fluid to get rid of any moisture from condesation?
  6. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    mudnut (12th December 2017), my93maverick (12th December 2017)
  7. #25
    Oct 2015
    Just picked up my new master cylinder $115 will pur it in this arvy and see how we go
  8. #26
    Oct 2015
    Ok guys so update is i got the new master cylinder in i can get it to the point where there is about 1 inch of pedal on the clutch but if i leave it in gear with the clutch in he car starts to creep fowards and lose the clutch but if i rake it out of gear then select it its ok still only little clutch and starts to feel abit crunchy three quarters of the way down nothing like it used to be?
  9. #27
    84 Post(s)
    Have you bled the air out of the system?
  10. #28
    Oct 2015
    We did but it might need some more im just not sure what the crunchy type feeling is in the pedal
  11. #29
    Patrol Freak gaddy's Avatar
    redlands
    Did you prime the master before fitting ? How is the flex hose , does it bulge when the peddle is pushed , did you bleed it at the slave ? Is the slave doing it's thing ? That gunk will be in the whole system .
  12. #30
    Oct 2015
    Quote Originally Posted by gaddy View Post
    Hi gaddy i didnt know how to prime the master first and what flex hose are uou talking about, slave is doing its this just feels weird and doesn't hold when in gear plus only have like 1 inch of clutch
