Results 1 to 10 of 14
Thread: Dts turbo kit gq td42
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    Gday all.
    Just got my new turbo kit,ive mostly got my head around where everything goes.
    Is the kit meant to come with instructions?
    There's one bracket i cant work out though,think it might be a turbo support?
    Any ideas people?
    Cheers in advance!
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Need a pic of the bracket .
    Apr 2017
    Hobart,tasmania
    It's the larger one.
    I presume the small one is for the aircleaner?
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Unless someone else knows I will check mine tomorrow which is also DTS and that bracket does look familiar.
    Apr 2017
    Hobart,tasmania
    Thanks heaps mate.
    581 Post(s)
    Nah it wouldn't be a bracket for the turbo, I would say both of those brackets are used to mount the airbox.
  8. The Following 2 Users Say Thank You to AB For This Useful Post:
    Deano2506 (27th June 2017), Rossco (27th June 2017)
    Apr 2017
    Hobart,tasmania
    Yeah. I'm starting to think that too.
    I'm pretty good with the tools but I'd like to take out the guess work.
    You'd think they'd include at least a diagram.
    Maybe it should've had instructions but my kit got missed
  10. #8
    581 Post(s)
    Quote Originally Posted by Deano2506 View Post
    I think I've seen bracket mounting on each side before, it's a pretty big air box!
    Flip the air box and see if those brackets match up to the box on fixings?
  11. The Following User Says Thank You to AB For This Useful Post:
  12. #9
    Correct. The one that is just bent at 90 degrees mounts to 2 of the exhaust studs and the other bolts to the intake manifold to support the airbox. The kit should have come with instructions.
  13. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    AB (27th June 2017), Deano2506 (27th June 2017)
  14. #10
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Just remembered that bracket , because to replace the top seal in the injector pump I need to remove the intake manifold and that bracket with it .
  15. The Following User Says Thank You to GQtdauto For This Useful Post:
