Results 1 to 10 of 15
Thread: Night driving on tight twisting tracks
    Mar 2013
    NE Melbourne
    Recently I had a couple of trips out to the High Country which required us to drive on tight twisting tracks (switchbacks) at night to get to camp. I only have driving lights on the front bar and was having difficulty seeing what was around the corner and where my rear tyre was going. I started thinking about a light bar on the roof rack as I would be able to see where my front tyres are going.
    Then I had a thought that maybe a couple of lower wattage lights pointing either side of the roof rack to illuminate the sides would be a better idea. I would be able to see down the sides of the car and what the rear wheel is about to run over. Has anyone done this?
    475 Post(s)
    G'day Rock Trol, haven't done it on my roof rack but have 2 x cheapo small square LED's awaiting in the shed for under tray mount side lights, same idea as yours mate!
  4. The Following User Says Thank You to MB For This Useful Post:
    Rock Trol (27th April 2017)
    I've always had an LED bar on the roof and you still can't see around corners. I have 2 smaller LED that I had always planned to mount facing outwards but never got around to it.
  6. The Following User Says Thank You to Winnie For This Useful Post:
  7. #4
    Feb 2012
    Camden, NSW
    Maybe small LED floods at each corner of the rack. Double as camp and repair lights.
    Wouldn't need much throw but a good wide beam.
    Maybe these
    http://www.supercheapauto.com.au/Pro...W-Round/283915
  8. The Following User Says Thank You to Turtle_au For This Useful Post:
  9. #5
    Patrol Guru
    Jul 2014
    6 Post(s)
    I've got 3 lightbars on my front bar, a 24" straight ahead and 2 x 6" at 45 degree angles which helps with the sides.
    As far as seeing the wheels, I usually get enough light pollution from the other lights for this, and always have a head torch/plenty of torches to do the job.
  10. The Following User Says Thank You to Throbbinhood For This Useful Post:
  11. #6
    A square 27 watt work light will throw heaps of good light.
    Might want to look at putting some bright LEDs under the Patrol
    pointing at the front wheels kinda like rock lights
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #7
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    The curved light bar on the roof rack has amazed me with how much light and where the light gets to , roughly equal to the front doors so don't anticipate switchbacks being a problem , if they are I can turn the two floods on the front to each side .
  14. The Following User Says Thank You to GQtdauto For This Useful Post:
  15. #8
    581 Post(s)
    I was about to ask if anyone has a curved light bar and how that shines on switchbacks like Barkley river at night tracks, etc.
  16. The Following User Says Thank You to AB For This Useful Post:
  17. #9
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Haven't tested it yet on tight switch backs but I get light out each side roughly level with driver .
  18. #10
    465 Post(s)
    I did see a Patrol with led strip lights in the wheel arches. Apparently this worked really well. But how well they would stay attached is another thing. I have a 5 mete roll in my garage, I've been wondering what I should do with it....
