Page 755 of 1057 FirstFirst ... 753754755756757 ... LastLast
Results 7,541 to 7,550 of 10566
  1. #7541
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Finally I have tacked together a trial on the drivers side mirror , tension of spring is about right , angles seem ok , but have to remake the saddle , although it fits ok the mirror won't fold completely front back if you hit something .
    I missed the slots needed so will remake the saddle with the slots needed , hopefully I should be done tomorrow.
    Probably not a lot of GQ's around with these baby's .
  2. #7542
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    The pics are all upside down? Looking good though!
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  3. #7543
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Bloody Microsoft ! Be a hipster and get an iPad .
    Yes I like the look of them too , Clearview don't make mirrors for the GQ so I had no option but I wish I knew how much of a prick of a job it was going to be , cost in materials so far without the mirrors is $2 yes just two bucks .
    I was lucky at the steel joint and they basically gave the stuff to me .
    I did buy a new welding helmet , a couple of cut of wheels and my 32 mm hole saw had vanished so had to get another one so it's not too bad cost wise .
    If anyone is ever thinking of doing this you will need access to a drill press and metal cutoff saw along with a welder and lots of patience .
  4. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    macca (4th May 2017), threedogs (26th April 2017)
  5. #7544
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Finally sorted out the whine from the belts.
    Changed the alternator belt for a new Gates brand belt, when I compared the two the old one was thicker with deeper teeth, must have been that, coz new belt and no noise at all.
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  6. #7545
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Right mirror in and wired up , left mirror on for trial fit and looks ok , bit more of an angle than test for some reason but happy enough to weld it up tomorrow and clean it up with the flap disk and paint it so should be all done tomorrow and have the door skins back in .
    I have rerouted the wires in the mirror on the right side so they come out of the bottom arm and that's a shit of a job but will do the same with the left one because it's a neater look .
  7. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    stevemc181 (26th April 2017), Yeti's Beast (26th April 2017)
  8. #7546
    @stevemc181 been using a digital temp controller for years as well, best mod ever IMO.
    http://www.nissanpatrol.com.au/forum...emp+controller
  9. #7547
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Yep, no problem with mine, makes it easy to set and maintain a constant temp.
    I finished off installing the ARB compressor yesterday and made use of the wing space on the left hand side of the drawers. Ended up making up a panel with space for three switches. I had no end panels for my clip together switch housings so I'll add these at a later time to neaten it up. It's all taking shape now and the Patrol is almost ready for her first adventure. The pic shows a water pump switch, but this is for future use as I haven't added a tank yet. There is also a blank space where I'll probably fit an LED light switch in the future.
  10. #7548
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Finally done with the Silverado mirror conversion to the GQ , have a small issue with the left side mirror sitting too far forward but I know how to fix it but have to remove it and that's a rainy day job .
    Blinkers work and the adjustment controls are fine .
  11. The Following User Says Thank You to GQtdauto For This Useful Post:
  12. #7549
    @stevemc181 can I suggest on all your accessories to change the ends from Cig socket to a merit plug.
    Much better will not fail well not as much as a Cig socket which will fail you can count on it. Still have a cig socket
    for that just in case situation, but a few merit sockets here and there for the win I reckon,,,,,lol
    Cig sockets and plugs are so old hat these days with some very good push,,twist ,,lock plugs going around,,,lol
  13. #7550
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I don't use any cig sockets, all mine are either the proper engel sockets which are a screw fit or they are anderson plugs. Never had anything come loose using either of these.
  14. The Following User Says Thank You to stevemc181 For This Useful Post:
