Page 358 of 565 FirstFirst ... 258308348356357358359360368408458 ... LastLast
Results 3,571 to 3,580 of 5642
  1. #3571
    461 Post(s)
    A litre bottle on Old No.7 and a 700ml of Tennesee Fire. And two bottles of red. Lol. @gubigfish. I have the same kit. I cannot grasp the adjustments of this thing. I either do them too lose, or too tight and the pull through the panel. Grrrr.
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I bought a redarc G52-EB, EGT and Boost gauge a few days ago, it arrived today and I notice it has a 1/8th NPT Male thread x 3/16" (4.75mm) Thermocouple Fitting, but I needed a 1/4" NPT male thread for my Manta 3" Exhaust. I had a couple of adapters at work for 1/8"-1/4" NPT, but these don't really allow the probe to sit in far enough if used.
    I ended up buying a standard SS316 compression fitting from Pro-Chem in Perth, (Part Number 3-CM4-316) 1/4" Male NPT to 3/16" Tube. The problem with the usual compression fittings for SS Tube is that they are not designed to allow the tube to pass right through. The easy fix is to throw a 5mm drill bit through it (I had no imperial bits) and all is good in the world. Total cost was $14.50, beats paying Redarc another $50 for their 1/4" fitting.
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  4. #3573
    461 Post(s)
    Quote Originally Posted by stevemc181 View Post
    I remember a similar thing mate when I put a 3inch pipe on mt 3ltr. So to fix that I simply cut the bung length down. Fixed in 5 minutes.
  5. #3574
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Not sure I follow you ? I needed a larger thread size fitting, the bung is 1/4" NPT, the Pyro fitting is only 1/8" NPT. Rather than use an adapter, I used a standard SS tube fitting.
  6. #3575
    461 Post(s)
    Sorry bud. The Jack is kicking in right now... The welded bung in the pipe I cut down in length, then the 1/4 to 1/8 adaptor can screw in further down allowing the probe to bet further in.
    I hope that explains it better.
    stevemc181 (5th April 2017)
  8. #3576
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Ahhh, got it now. I was going to cut my adapter in half, as it was fairly long but decided on just buying the right size fitting and drilling it out so the probe would fit through. Hopefully I can get the EGT gauge fitted this weekend, I also bought the Boost fitting kit that 3D linked to above, so should be good to go.
  9. The Following User Says Thank You to stevemc181 For This Useful Post:
    threedogs (6th April 2017)
  10. #3577
    49 Post(s)
    You talking Jack, mudski...
  11. The Following User Says Thank You to jay see For This Useful Post:
    mudski (5th April 2017)
  12. #3578
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    After much pissing around (about 3 days) I've finally managed to buy a pair of Silverado mirrors for the GQ , trying to get the plain one with just electric adjust that would ship to oz was a nightmare , one company wanting $99 for mirrors and $199 delivery .
    This one has blinkers and god knows what else for $119 our money plus $23 delivery their money so I still get it for under $150 delivered .
    Still have to make a bracket to suit the GQ but I think I can do it , might even hook the blinkers up but not sure I need heated function .
    https://vod.ebay.com/vod/FetchOrderD...70000010006850
  13. #3579
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Link doesn't work apparently but they are the same as the GU owner had but basic black in colour .
  14. #3580
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Got a refund for 4 old camping mats that were leaking air and then got 4 new replacement ones!
    Then whilst I was there, also bought a new tent for the family from Costco for $120 - one of the Coleman instant tents which will hopefully made set outs a lot easier!!
