Results 1 to 5 of 5
Thread: GU 4.2 Wagon manual gearbox.
    Expert Tonks's Avatar
    ACT
    G'Day all,
    How many litres of oil does the gearbox take ?
    What oil would you recommend ?
    Cheers,
    Tonks.
    2004 GU111 4.2 TURBO WAGON, 2" OME SUSPENSION, 33" MTZ's, 3" BEAUDESERT EXHAUST, ARB ROOF RACK, ARB AWNING, BLACK WIDOW DRAW SYSTEM & CARGO BARRIER, DUAL BATTERIES, 12,000lb WINCH, GME UHF, LIGHT FORCE XGT SPOTTIES, BERRIMA DIESEL TUNE.
    Aug 2011
    River Heads Q
    4 Post(s)
    Quote Originally Posted by Tonks View Post
    G'Day all,
    Cheers,
    Tonks.
    Straight from original Nissan hand book that came with my 2006 4.2TDi
    Gearbox API GL4 SAE 75w85. Gearbox 3.5lt
    The Haynes workshop manual advises SAE 75w90 API GL4
    I am using Fuchs oils for everything now (new local dealer with good price) but was using Penrite with no problems but was expensive.
  3. The Following User Says Thank You to Wizard52 For This Useful Post:
    Tonks (5th February 2017)
    ACT
    I ended up putting in Castrol VMX80, very smooth gear changes now.
    Hardcore
    central coast nsw
    My gen manual recommends API GL4 75-90w only.
    the only is actually written in there, not my input.
    Manual was released with the 02 model & printed in 2001.
    personally I'd stick with the higher W given todays pushing 40c
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
    177 Post(s)
    Exactly what I filled my cog box with. Unsure what was in it prior, but it's very smooth after that.
