25th August 2014, 08:02 PM
#331
Administrator
Bloodyaussie
?????????????!!!!!!!!!!!!!!!!!!!!!!!!!!??????????? ??????????????? what you on about?????????????????????????????!!!!!!!!!!!!!!!! !!!!!!!!!!!!!????????????????????????????
I personally dont like powder coating for bar work as once it is chipped away it is hard to tidy up.
I prefer paint then it just needs a dust up every now and then.
I only got the Bar primed as I was not sure how long until you would paint it so did not want it to rust.
The scrub bars I did not get primed as I knew I would be painting straight away.
I could bring the bar to the ARB night?? I am going to need your bar pretty soon.
Yeah no probs mate. ill have to strip my bar at home but I can take the rodeo at work and bring the bar in the tray as it will be a pita trying to get everything back on in the car park at 9pm at arb.
Do you want to do that?
I just didn't know if you were just going to leave my bar as is and throw it on your car or if you were going to spruce it up and respray it. It's actually in pretty good nick, no dents or deep scratches, etc...
25th August 2014 08:02 PM
25th August 2014, 08:30 PM
#332
So was there a reason you picked a wrx cooler, or was it just what you had? I'm looking at buying one of these from justjap:
Mainly because the piping for my RD28 GQ will be so much easier then having to pipe it all the way back round. I plan to either mod my stock plenum to be like this:
Or use a GU RD28 plenum, and rotate the intake 90 degrees.
97 GQ RD28t Wagon, needs a new crank
25th August 2014, 08:53 PM
#333
Administrator
MrSka
Purely because a friend was giving it away mate with a lot of piping that could work that's all. I won't lie though, it was a bit painful trying to get it all to work though being a full custom fit.
The Following User Says Thank You to AB For This Useful Post:
24th September 2014, 11:38 PM
#334
Haven't ever tuned my turbo. Probably why it seems like there isn't one there
24th September 2014, 11:40 PM
#335
Do you know if anyone has put an atmospheric blow off valve on a gq before??? just curious
25th September 2014, 07:03 AM
#336
Moderator
TurboYoda97
No point on a Deisel mate.
Check out my Toy -->
Rogue Dung Beetle
25th September 2014, 07:11 AM
#337
Smart like tractor
TurboYoda97
Only need one if you run big boost and suffer from compessor surge. The kit is about $700 from memory
96 GQ coil/Cab
08 G6eT
5th January 2017, 10:19 PM
#338
Patrol Guru
Thread dig here sorry mate! To get your cooler back you cut that vertical bonnet catch steel bar off and took off your aircon thermo?
Any negative affects on aircon? And any affects of removing that support?
How's the cooler lasting over the rigures of 4 wding?
Nice work too mate keeps it subtle!
6th January 2017, 07:17 AM
#339
89gqpatrol4x4
Hey mate ABs away for a few days but have a front mount on my GQ. Yeah removed vertical support just a couple of bolts top & bottom. Didnt notice any difference really maybe bonnet needs a firmer slam to shut but that might just be my catch. Took off the thermos for the aircon too, still works beutiful the only loss will be aircon might not get icy cool if just sitting there idling cos it's not getting airflow but hasn't been an issue at all with mine really. .
6th January 2017, 07:59 AM
#340
Patrol Guru
Cheers Rossco. Did you run your pipe work the same and did you rubber mount the intercooler ?
