Results 1 to 8 of 8
Thread: Removing A/C evaporator from GQ Patrol
    Feb 2013
    Adelaide
    Hi all,
    Has anyone Removed the A/C evaporator from a GQ Patrol, and have any helpful hints.
    The first thing I would like to know is if the dash needs to be removed or not.
    Thanks for any help.
    Mark
    Legendary dom14's Avatar
    38 Post(s)
    Why do you need to remove the evaporator?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Feb 2013
    Adelaide
    Hi,
    Need to replace
    Last time I had a/c problem I checked in the box and the fins were half corroded away.
    Don't no why, 1 owner nothing sprayed in there and was clean inside (no leaves)
    So now needs a gas so I suspect its corroded though a tube now.
    Expert johno90's Avatar
    Moranbah QLD
    Gq evaporator is about as easy as it gets
    1. Get the system degassed if any in it
    2. Remove lines from firewall side
    3. Remove glove box
    4. Remove wiring connectors to case
    5. Remove the 10mm bolts mounting the case
    6. Remove whole evaporator case (slides back then down then back) but you will see what i mean when you do it
  6. The Following User Says Thank You to johno90 For This Useful Post:
    dom14 (20th July 2016)
    Expert Arfa Brayne's Avatar
    Jul 2016
    Quote Originally Posted by johno90 View Post
    3. Remove glove box
    Isn't that just the blower fan case ?
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
    Moranbah QLD
    Umm nope. Fan case is the case to the left with the motor sticking out the bottom. Evap case is in the middle and is very easy to get out once you know how. Even on a gu there is no need to remove dash to do evap or heater cores. If you want next time i do one ill take some pics and make a how to.
  9. The Following 2 Users Say Thank You to johno90 For This Useful Post:
    Arfa Brayne (23rd August 2016), mudnut (22nd August 2016)
  10. #7
    That would be a an excellent idea.
  11. #8
    Moranbah QLD
    Will do in a few weeks gotta replace the evap on the old mans gq when i get back to Brisbane
