Results 1 to 10 of 14
Thread: ZD30 intake butterfly removal
    Expert Daveyboyjunior's Avatar
    Feb 2015
    Dartmoor, England
    As title. Why is this deemed a necessary mod?
    EGR has been removed, and throttle body cleaned....
    465 Post(s)
    Its not necessary bud. Dont bother. you wont gain anything from doing it. The large butterfly assists in engine shut down, and the other i like a choke where it closes to richen the fuel mixture. Or something to that effect.
    But if your keen to see the difference, just leave the vacuum tube of it so it wont work and just stay open.
    Feb 2015
    Dartmoor, England
    Thanks Mudski.
    I've heard of it, just wasn't sure of the reason or affects it might have.
    Dec 2015
    WA
    5 Post(s)
    It will shudder & shake like hell on shutdown.
    Graham
    Feb 2015
    Dartmoor, England
    Aah, we'll do without that then!
    Jun 2016
    Fraser Coast QLD
    Quote Originally Posted by Daveyboyjunior View Post
    Yeah its one bit of Nissan Engineering that does make a positive difference to the ZD hahahahaha
    Who compares TD4.2s to ZD30s anyway? Its like saying your mums SS is better than your little sisters Camira.....
    Advanced caveman21's Avatar
    May 2016
    sandgroper
    Wow thats some serious crud in that throttle body ,maybe have to check mine before i install the new intercooler i have a oil stain on my ic where it has been leaking so more than likely throttle body full of crud too ? just blocked the egr 2 days ago
    Why do caveman drag there woman by there hair ?
    Cause if you drag them by there feet they fill up with dirt
    Quote Originally Posted by caveman21 View Post
    You could remove your IC and clean the inside, Wouldnt bother testing it for leaks if its oily.
    Diesel Smart do a great tigged IC pressure tested to 60 psi I think, good service too.
    check that rear hose [blue] on yours they have a tendency to blow off or split
  10. #9
    May 2016
    sandgroper
    3D I have a new intrcooler arriving monday -tuesday i will prob get new hoses for all the pipework on the IC as they all look a bit dodgey
    was thinking about going 2.25 inch (57mm) from turbo to intercooler had a look on ebay but found it hard to find all the parts needed
    this is what i think is required
    2.25inch (57mm) 90deg mandrell bent pipe
    2.25inch(57mm) 60deg mandrell bent pipe
    2.25inch (57mm) straight sillicone joiner x2
    1.75inch to 2.25inch reducer silicone joiner
  11. #10
    Feb 2015
    Dartmoor, England
    Here's my new new Tigged IC all the way from your side to mine in 5 days! Awesome!
  12. The Following 2 Users Say Thank You to Daveyboyjunior For This Useful Post:
    BigRAWesty (18th July 2016), caveman21 (18th July 2016)
