Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 2012 long range sub tank best option
    Quote Originally Posted by abw View Post
    I read somewhere some having problems with the LRA tank and the tailshaft hitting on full flex. Though this may only be a problem on higher lifts. I had a Brown Davis fitted. It's 75L. I'd have to say it's a tight squeeze..they use every square centimeter of space! It doesn't hang down any further than the muffler and the steel side step brackets.
    It does sit close to the tail shaft. Mine was rubbing on my last trip because my fuel tank copped a hit and it bent out a bit.
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Do you reuse the pump from the Nissan tank on the LRA or is an external pump used.
    Looks like the brown David tank used the original Nissan pump setup.
    What height lift do you have have and are you happy with the setup.
    2012 GU8
  4. #13
    Mine is on a GQ so it did not have a tank their from the factory.
    I have a 2" lift and adding this fuel tank is one of the best mods I have done to the car.
  5. The Following User Says Thank You to Winnie For This Useful Post:
    rusty00 (21st June 2016)
  6. #14
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    Well, I'm pretty heavily loaded so economy is terrible. Lots on the roof too. Getting about 16l/100 and around 19 in the desert. So about 1000km if I behave..
    Used 134l to go Birdsville to Mt Dare. 690km.
    Quote Originally Posted by rusty00 View Post
    How many km did you do to fule usage.
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
  7. The Following User Says Thank You to Boinzo For This Useful Post:
    rusty00 (22nd June 2016)
  8. #15
    When ever the time comes to do the big lap, then I'll be fitting a 150 ltr Brown Davis number.
    but very happy with my range ATM, Brown Davis used the OE sender from the old OE sub tank.
