Results 11 to 20 of 21
Thread: Vibrating sound?
    @SKID what area are you in , Melb west I think
    If so bring it around as two heads are better than one
    Mar 2013
    Wish I could, but Live in Brisbane QLD
  4. The Following User Says Thank You to SKID For This Useful Post:
    threedogs (6th June 2016)
  5. #13
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    If you have checker plate on your sliders
    could be the riverts starting to come loose
    and vibrating through the steel work
  6. #14
    My tread plates[side steps] are loose I ended up packing them up with pieces of small cable ties
  7. #15
    Mar 2013
    No checkerplate on rock sliders... when it made the noise today, if I touched the accelerator pedal ever so slightly to bring the revs uo from 750 to 800ish the sound goes away... Any ideas?
  8. #16
    475 Post(s)
    Quote Originally Posted by SKID View Post
    G'day SKID, have you tried everything else suggested above, especially Kimbo's idea? Definately no mounts rubbing steel on steel again? Not sure what Donk you've got but is 750 too low anyway? Cheers :-) !
  9. #17
    Mar 2013
    Its a TD42 with turbo... Truck was originally a 3ltr but the previous owners blew it up and put a TD42 silvertop in...
  10. #18
    475 Post(s)
    So all new mounts all over are good, have checked? NissanNewby would know the correct idle for a silver turbo but the poor buggers super busy :-)
  11. The Following User Says Thank You to MB For This Useful Post:
    SKID (13th June 2016)
  12. #19
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    mine is a silvertop td42 in a gq and it seems to make the same sort of noises. did find the clutch shield loose as in it was cracking off. but it still makes the noise. my body mounts are still original... i've given up chasing the noise for now but if you find it i'll consider fixing it...lol
  13. #20
    Mar 2013
    What should I adjust it too? its currently on 750RPM
