Results 1 to 10 of 10
Thread: Engine power upgrades-4.2 intercooled turbo diesel
    Aug 2011
    G'Day all,
    wanting to get advice on the most logical steps to increase power/torque in a factory 4.2 intercooled trubo diesel G.U. And where is recommended to get the work done, preferably in bris or on gold coast .
    she has had a dyno, 3" exhaust, and pyro fitted by AMMS about 4 years ago.
    From memory she is now pumping out a neck breaking 100kw !
    Ute has only done 120,000km.
    as were now towing a 2ton van around, she is a bit lacking up big hills.
    although the EGT never gets above 550 max, and water temp never changes.
    Id like to increase power without going nuts, and reducing engine life.
    your input greatly appreciated !
    Cheers, Marty.
    175 Post(s)
    G'day Marty. Welcome to the forum.
    Plenty of people here to help you out.
    Although, You may be waiting on an answer for a few days as a lot of the experts are at the forum piss-up today/tonight. Nissannewby seems to know the 4.2's inside out so, I dare say he'll responds next few days.
    As for my experience, I too had 3" fitted, EGR blocked and then dynotuned and she returned 100kw! Car went great after that, really opened her up and dropped EGT's. I'm happy with the power, nothing over the top and safe and sustainable. Now I've got the bigger cooler fitted and there is more potential now.
    Next steps would be increasing the throat (air intake) girth and obviously the expensive stuff like upgrading turbo and pump.
    As I said people in the know how will reply later. But do a quick search also, plenty of threads on the same topic.
    Aug 2014
    Perth
    10 Post(s)
    I've done a bigger inter-cooler and 4" snorkel attached to the factory Airbox Marty. After fitting these I then took it to get Dyno tuned see the attached report. The acceleration is much greater now and puts a smile on my face every time I drive it. I have bigger plans yet but need funds to keep going.
    Whether its enough for your van I couldn't tell you. The other thing to consider is if you have put bigger tyres on i.e. 33" have you looked at your diff ratios?
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    welcome to the Forum Marty
    depending on what year your 4.2 is, will help in determining what you best direction to go
    is it a N/A (Naturally Aspirated) with Turbo fitted
    or Factory Turbo
    or Factory Turbo & Intercooled............
    how much Boost are you running...........
    what size Tyres...........
    what Diff ratio's do you have...........
    these will help the more knowledgeable people than me help you....
    Aug 2011
    Awesome, thanks for the input Hodge. I'll see what the other boys have to say too.
    Thanks again.
    Aug 2011
    Thats a pretty good increase just by fitting a bigger diam snorkel !
    Cheers gubigfish.
    Aug 2011
    Hi Bigcol,
    cheers for the reply.. as much as know as follows..
    depending on what year your 4.2 is, will help in determining what you best direction to go-2004
    or Factory Turbo
    or Factory Turbo & Intercooled..........Factroy turbo/intercooler
    how much Boost are you running...........no idea, dont have a boost gauge.
    what size Tyres........... 33's MT
    what Diff ratio's do you have........... standard from factory..?
    cheers in advance for advice.
    Aug 2014
    Perth
    10 Post(s)
    Quote Originally Posted by qldmarty View Post
    Cheers gubigfish.
    and a bloody great big intercooler too see below. Forgot to mention she also has a 3" exhaust on her as well.
  10. #9
    Jul 2015
    ORANGE NSW
    hi all the biggest incress I got from my 2004 4,2gu was when I took off the EGR picked up more get up an go runs cooler and better on fule hope this helps///
  11. #10
    Blocking the egr or removing it and removing it the intake butterfly is one of the best mods you can do for engine longevity.
