11th May 2016, 02:56 PM
20+ Psi coasting
So I have one for the pros..
I've noticed after the exhaust has gone on when I'm coasting with cruse on or a pedal position just before engine braking comes on, or acceleration boost is running up to 20+ Psi. . Highest I seen was 26!!!!
When engine braking it's right down at sub 1 psi and under any sorta acceleration it's fine and maxes out at 15 as it should..
Not sure if it's the turbo over running or a faulty sensor??
Could it be not enough back pressure??
Help. I'm now worried about this weekend..
I've got 2000 road k's ahead of me!!!
11th May 2016 02:56 PM
11th May 2016, 03:09 PM
Dribble Master
Just drive the damn thing
11th May 2016, 03:14 PM
Clunk
Nek minute pin drops....
11th May 2016, 03:55 PM
Boost wont kill it. What are egts like while this is happening?
Is your gauge absolute or is it corrected?
11th May 2016, 04:03 PM
nissannewby
Unsure on egt as yet to fit gauge..
Water temp doesn't move from the normal 88-90 though..
I can't hear the turbo spooling like I can under power.
Scangauge is reading corrected boost so you may be onto something..
11th May 2016, 09:29 PM
Patrol Guru
What's going on here Kallen? You right for the weekend ?
98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
"GO YOU CROWS"
11th May 2016, 09:36 PM
1998 GU RD28T: RIP
![Frown](images/smilies/frown.png)
Hello 2012 GU CRDZD30
11th May 2016, 09:42 PM
#8
Chubba
I bloody hope so!!!
trekster
blocked egr?
Yes..
Never thrown a code
12th May 2016, 06:05 AM
#9
When I blocked my egr and put 3" exhaust on, without boost control, The ecu couldn't control the boost and if I was just cruising with bugger all foot down the boost would go up to like 25psi+ If I put my foot down there was no problem it would drop back, but couldn't cruise at all.... Might want to check your boost control setup assuming you have a dawes/tilix etc.
1998 GU RD28T: RIP
12th May 2016, 06:36 AM
#10
SUCH IS LIFE
Just clean your MAF and all your issues will magically disappear ![Wink](images/smilies/wink.png)
Sounds like a typical 3" exhaust over boost issue, time for dowes valve I reckon.
….................... On the move
________________________
______ 2017 D-Max _______
The Following User Says Thank You to Maxhead For This Useful Post:
BigRAWesty (12th May 2016)
