Page 81 of 101 FirstFirst ... 3171798081828391 ... LastLast
Results 801 to 810 of 1003
Thread: Hodge's new 4.2
  1. #801
    43 Post(s)
    Quote Originally Posted by Rocket55 View Post
    They do package them well don't they, a few others could learn from them.
    Just make sure you cut the hole in the bonnet in the right spot... Don't want to get that wrong.
    Maybe a quick read up on a few threads for the don't do's
    Patrol Guru Rocket55's Avatar
    Sydney
    Seriously, who'd get that wrong Maybe I should have read that thread...
    Cheers Rod
    My Build 2005 TD42TI
  4. The Following User Says Thank You to Rocket55 For This Useful Post:
    BigRAWesty (9th May 2016)
  5. #803
    465 Post(s)
    Thats why i opted out to cutting my bonnet. I wasnt game enough.
  6. #804
    175 Post(s)
    Finally had a moment to check out the full contents. Everything checks out, no dents, as far as I can see everything needed is here.
    Got to actually see the true size of this cooler by holding in and the scoop and it's pretty big. Scoop as well. Scoop just a tiny bit bigger than the factory scoop.
  7. The Following 6 Users Say Thank You to Hodge For This Useful Post:
    Bacho86 (10th May 2016), MudRunnerTD (24th May 2016), mudski (10th May 2016), Rocket55 (10th May 2016), Stropp (10th May 2016), Woof (10th May 2016)
  8. #805
    Sydney
    Wait till you drive it with the scoop on, half the bonnet and bullbar disappears....
    Cheers Rod
  9. #806
    They are an awesome looking scoop... I love mine.
  10. #807
    Aug 2014
    Perth
    10 Post(s)
    Takes a bit to get used to the first few times you drive it after fitting the scoop
  11. #808
    175 Post(s)
    Just going through paper work etc... I have to admit the instructions for the scoop install are a tad piss poor.
    Most of the instructions and photos are about the intercooler install, which is pretty much a bolt on out of the box and very hard to get wrong. But only 2 bits of paper (template and a poorly written A4 page )on fitting the sccoop.
    Some instructions arrived on a DVD in PDF format etc...
    The guy told me to call them when fitting to explain, easier to explain over the phone how it works because they do them every day.
    I asked them why not make a video of one of their installs and put that on a DVD instead... Would help immensely.
    @Rocket55
    I can now see how easy it was to stuff the scoop cut-out. Not very hard to do.
    Sydney
    Yep, glad you said that, as I'll run with that too.
    Although it should have twigged with me whilst I was cutting out the curved hole, how did everyone else do this with a 4" angle grinder and 1mm thick cutting wheel, but alas it didn't
    After getting used the the view with the scoop on, got to admit, it did feel funny driving the Cruiser with no scoop at all, kept thinking something was missing or wrong...
    Cheers Rod
  13. #810
    465 Post(s)
    Your driving a Cruiser Rocket. Thats Whats Wrong. Lol.
    Eric I think you mount the cooler first and ontop of the cooler on the foam you peel this off I think, shut the bonnet, and then this foam makes a mark for where you are supposed to cut. I think thats how it goes. I spoke to a guy and he mounted it all and put grease on the foam then shut the bonnet. This gave him a good line to go by.
    Just remember when cutting with a grinder to cover your windscreen and all unprotected paint work. Hot metal flying everywhere and glass/ paint, don't go together well.
    And take your hood insulator off too. Lol.
