Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
Thread: A Guide on installing your own remote central locking in under 20 minutes
  1. #41
    ebay job mate "crimefighter brand". I really only wanted something to replace central locking with an audible alert. I wont be using most of the features of this, but for $40, cant go wrong LOL.
    I just hope the wiring I have above is correct...
  2. The Following User Says Thank You to shaun100 For This Useful Post:
    jay see (4th May 2016)
    465 Post(s)
    If its not correct if wont work.. Looking at the door lock/unlock wires it seems you have got it right. The 12v feed wire you have it on Yellow. I would say it goes to the red. And not to use the relay. The relay is for the shock sensors etc etc so when you turn the ignition off it activate the relay to disable the shock sensor. The indicators are correct.
  5. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jay see (4th May 2016), shaun100 (4th May 2016)
  6. #43
    well I have tried and isnt working.....Wired as above, but with red wire as posative instead of yellow (originally a typo).
    I can see the wire on the central locking getting a positive feed when locking, but it aint locking the door.....
    Any suggestions...PLEASE??
    looking through other threads, should the original plug that was to the factory keyless entry be earthed via black wire????
  8. #45
    465 Post(s)
    Quote Originally Posted by shaun100 View Post
    Worth a try I suppose.??
  9. #46
    Got it sorted. There were a couple of wires on alarm central locking that needed to be earthed. Now another problem. Theres a blue wire on alarm that needs a negative signal from the door. I pulled out the door switch and they are positive?? The alarm wants to rearm 20 or so seconds after I unlock and open the door, and Im guessing its because its not getting the neg signal from door light. Any suggestions guys? Thanks
  10. #47
    465 Post(s)
    Hmm sorry. Im out on this part. Hopefully one of the guru's will pop their head in. @Yendor @the evil twin . That might grab their attention.
  11. #48
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The interior door light switches are negative switched. Try opening and closing one of the other doors when checking the drivers door switch.
  12. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    mudski (6th May 2016), shaun100 (6th May 2016)
  13. #49
    465 Post(s)
    Thanks Rodney...
    What rims you have too mate? Sorta look like the Dick Cepek DC2's. Been contemplating splashing out on some.
  14. #50
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Thanks Rodney...
    Wasp
    http://www.alliedwheels.com.au/produ...lack-machined/
  15. The Following User Says Thank You to Yendor For This Useful Post:
    mudski (8th May 2016)
