Page 30 of 44 FirstFirst ... 20282930313240 ... LastLast
Results 291 to 300 of 434
Thread: Threedogs motor thread
  1. #291
    Its a mighty ZD30 what could possibly go wrong.
    famous last words.
    Least you have a sense of humor about it lol
    Sent from my S50 using Tapatalk
  2. The Following User Says Thank You to rusty_nail For This Useful Post:
    threedogs (28th April 2016)
    Pad... 292 Posts and counting
    Not much longer and I'll have 5,000 posts and be able to use sarcasm
  5. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (28th April 2016), rusty_nail (28th April 2016), Touses (29th April 2016)
  6. #293
    Oct 2010
    Old Bar, NSW
    I admit to not knowing a lot about these engines, for you to keep blowing hoses etc there must be a pressure build up.
    Main place to get that sort of pressure is from a pot? Reckon there is a head gasket or some other passage allowing pressure in the cooling circuit.
    You seem to be like a cartoon character who has run out of hands trying to plug the leaks, stop one and another starts.
    Not much help I know, just feel you are not in the right area to find whats wrong, fixing the result not the cause.
    Macca
  7. The Following User Says Thank You to macca For This Useful Post:
    Hodge (28th April 2016)
  8. #294
    As per a previous post so the same thing didnt post again the motor needs to be running for it to be tested
    also from a previous post Ive lined it up to be tested once its going, So again Ill tilt tray it home tomorrow as per a previous post
    repair if possible whats leaking as per a previous post and then get it TESTED, I cant be any clearer than that, lol
    No doubt others will ask the same thing lol
  9. #295
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Yeah I'm very confused trying to follow this thread too.
    So is it getting hot and boiling over which is then pushing out the coolant (water) or is it losing the coolant (water) and therefore getting hot?
    When the thermostat housing repair was done it wasn't leaking from there but now it is. Would that mean that if there's a leak there its coincidently gotten a lot worse in a couple of days?
    You said it's coming from the thermostat housing but are going to pull bits apart to get to that little hose.
    Surely if you start with a dry engine then get a torch and watch closely (even with an extra set of eyes helping) you should be able to zone in on the leak better?
    It's been losing coolant (water) for a long time but hasn't been losing it from the thermostat area until yesterday?
    Also, as you've been keeping a very close eye on any slight degree change in temperature, I wonder if there's a discrepancy between water vs coolant? If it had coolant in there would it be reading the same temps?
    As has been said above, even if money is tight you should really get a few tests done by a professional.
    >>>tappin from tassie
    Hello from Under Down Under!
  10. #296
    its coming from that area again I dont have xray vision.
    I doubt its leaking from the TS housing only that area
    again with a torch and xray vision turned off it seems to come from the area
    above the TS housing or there abouts, with xray vision turned on I couldn't pin point
    to an exact area, AGAIN when its running its getting TESTED professionally.
    better turn my xray vision off sons girlfriend just walked in lol
  11. #297
    465 Post(s)
    That was because a known 4x4 shop owner who helped here a few years back
    did not put coolant in my motor, I did not notice till it was too late.
    if not the owner it was his off sider. why do you think I never go there anymore
    wouldnt take my lawn motor to them.
    I may have brown in the pipes but I dont think any well hope not are corroded
    find out soon enough
    So its been without coolant for a few years?! If those pipes arent corroded i will be very surprised.
  12. #298
    49 Post(s)
    Glad you can still laugh about.
  13. #299
    Time will tell, time will tell
  14. #300
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    So im really confused over all this,
    You convey yourself over the forum as someone who has alot of knowledge about patrols yet its really only about nads more then anything, but this problem seems to be a big witch hunt.
    I'm not sure if tou fall into the knowledgeable category or more into the chick category who drive a vehicle, put fuel in it then when something breaks are unsure as to why...
    You say you had work done and by the time you found out it had water in it and not coolant it was too late, how many kms was this? 1,5, 50k km? If it was more then a 1000km then that shows you don't maintain you car well enough and only have yourself to blame for all this.
    I honestly see you as having 2 realistic options here:
    Take it to a mechanic tell them whats going on and let them fix it properly,
    Or
    Sell the patrol, buy a toyota corolla which go forever and be done with the whole "modified vehicle" scene as it doesn't seem to suit you.
  15. The Following User Says Thank You to trekster For This Useful Post:
    macca (28th April 2016)
