Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 56
Thread: Fridges....
  1. #31
    174 Post(s)
    Quote Originally Posted by qwertytank View Post
    Has anyone got/used/seen/know anything about this Fridge?
    Giant Power - Fibreglass with Danfoss compressor
    http://www.aussiebatteries.com.au/ca...fridge-freezer
    Looks reasonable to me. A known quantity in the compressor, a decent warranty as well as 2” insulation which is as good or better than a lot of the common models. I wouldn’t call it cheap, but it does seem reasonably priced in comparison to what else you can buy. I like the internal lids as well as the the main lid.
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    qwertytank (16th December 2015)
    Dec 2015
    Well, with minimal research, I went for a Waeco 40.
    Good bad or indifferent, it is done now, let the chips fall where they may.
  5. #33
    Quote Originally Posted by RedRoadRunner View Post
    Just make sure you have good connections and steady 12 v supply .
    You should have no problems IMO
  6. #34
    Dec 2015
    I've got a second battery on the way...
    Might do a little 12v wiring on the weekend...
  7. #35
    Give any cig sockets the flick they do fail and not the best going.
    use either twistlock Engel/Baintech style, even 50 amp anderson will
    do the trick. Make sure your wire is adequate to carry the current to the rear of the Patrol,
    Even a merit socket and plug would be OK
    When you fit your Dual battery tray please use Mudguard washers [penny washers]
    and nyloc nuts, Ive seen too many GQs with broken inner guards from poor fitting
    practices.
  8. #36
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Ah typo for me... ha ha meant 220V
    But yes that 2nd one does look better. So have you installed this into yours?
    Interesting idea... Got a mate that had a busted engel I should try and fix
    Ive used this temp controller on my engel setup too mate. Works a treat.
  9. The Following User Says Thank You to sooty_10 For This Useful Post:
    threedogs (16th December 2015)
  10. #37
    Dec 2015
    Well, after a little retail adventure, getting all the tools ready, and spreading shit all over the kitchen table to do surgery....I realised that the Waeco plug just has a little sleeve on it you can take off and it fits in a merit socket.
  11. #38
    Doh,,,, welcome to the club, now to mount the
    Merit somewhere where it cant get knocked .
  12. #39
    Dec 2015
    Right above the fridge, so I can snap the plug when I open the door incautiously.
  13. #40
    There are a few options to mount it, I have used an Engel transit base ,but that wont work for you.
    There are two styles of fridge slides one slides and the other $$$$ slides and drops down.
    Make sure you restrain the fridge from moving around maybe use some rachett straps.
    Where are you putting your fridge???
