OK, so I have a bit of an issue with my 2014 GU Patrol. The previous owner fitted some (not exactly road legal) 35" muddies to it and to prevent them from rubbing has removed the front mud guards and cut out a section on the underneath of the front flares. The problem now is that when driving through any reasonable depth of water, the wheels throw up all sorts of debris into the inside of the flares through the hole that has been made in the bottom. I'm planning to block this off or put on some generic guards but I'd like to clean out all the crap that got caught up in there from previous trips.
How easy is it to remove the flares? I undid the screws around the wheel arch and the one at the very bottom but couldn't work out why it still wouldn't budge and didn't want to break anything so I ended up putting it all back together. Is there a trick to it or should I just be using brute force?
Thanks in advance.
There are a combination of screws, press clips and slide clips. Can you post a pic of the cut the guy made? I have cut mine but don't have the same problem your describing?
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
Yeah sure, I'll post one up tomorrow.
The only reason I noticed it was collecting crap was there were twigs sticking out between the rubber sealing strip on the flare and the body panel last time I went through a big puddle. Granted it was a knee deep puddle but there must have been a fair bit of water pressure up in there to force stuff through that gap.
OK, here's a couple of pics I took. Sorry it's a bit difficult to get in there to photograph properly.
As you can see the corner chunk has been neatly removed with a blunt axe, or a rusty spoon perhaps... 20151124_165413.jpg 20151124_165502.jpg
Doesn't leave much to attach a guard to but I'm sure I can come up with something.
Hmmm. I'll look around. Someone may be wrecking a GU somewhere. Problem is I'm not sure there's much left of the flare to attach them to.
I'll check with the dealership I bought it from since they were a decent bunch.
