19th November 2015, 06:50 PM
#21
Thanks ET.
Now back to smoking of a nice piece of pork and beef coated in crushed pepper and a dash of honey...
The Following User Says Thank You to outback For This Useful Post:
BigRAWesty (19th November 2015)
19th November 2015 06:50 PM
19th November 2015, 07:15 PM
#22
Patrol Guru
Yeah as said the override is basically an inbuilt relay so draws sweet f a amps when engaged, just needs 12v.
19th November 2015, 07:23 PM
#23
I am he, fear me
outback
Thanks ET.
Jeez man, I'm nearly drowning in saliva thinking about how good that would be... I am so gunna call in to your place next time I cross the Nulla'
19th November 2015, 07:33 PM
#24
the evil twin
They are looking good, been on for about 4 hours. Vegs on the BBQ hotplate next..
Let me know when you decide to do drop in.. smoked pork ribs are really nice ...
the evil twin (19th November 2015)
19th November 2015, 07:50 PM
#25
i have the sbi212 controlling my dual bats with an override switch for winching off both. works a treat have had the gq buried deep in nasty clay(tried to drive a dry dam) definetly helps having both batteries, be sure to use a good heavy cable to link them. also look at a hybrid type battery to better handle the high amp draw of winching etc im using a supercharge allrounder 100ah/700+cca. its a good simple system that works really well
The Following User Says Thank You to billyj For This Useful Post:
Rossco (19th November 2015)
19th November 2015, 07:59 PM
#26
I am reding most of the existing wiring so its being upgraded to deal with the amp load.
19th November 2015, 10:18 PM
#27
also consider fitting a heavier charge cable from the alt to main battery
19th November 2015, 10:22 PM
#28
Doing all that anyway as the BS 12 needs a heavy cable vs the current thing there.
Also making sure the +ve and -ve to the new winch are heavier vs the current ones.
The nasty bit is the controller, it's all plastic. So I have to make a metal backing plate so everything hangs on that vs a plastic one.
21st November 2015, 05:04 PM
#29
Additional query:
Is it worth while looking the two -ve battery terminals with a cable, same size as the +ve one?
At present both batteries are earthed at different points.
21st November 2015, 05:24 PM
#30
I am he, fear me
outback
Additional query:
Can if you want but the thickest, heaviest, largest earth cable you can fit is "Patrol B&S"... that is what Nissan and I both use
