Page 641 of 1454 FirstFirst ... 1415415916316396406416426436516917411141 ... LastLast
Results 6,401 to 6,410 of 14533
  1. #6401
    Perth WA
    61 Post(s)
    Not sure if this would make any difference but when cleaning rust off camp ovens everyone soaks them in molasses..1 part molasses to 10 parts water, just a suggestion as nothing else seems to work
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
  2. The Following User Says Thank You to Woof For This Useful Post:
    Avo (16th October 2015)
    I reckon given its unbolted you can walk into a decent Auto shop that has at least a 20ton press and ask them to press it out. It might cost you $30 which you won't spend on Inox, crc and hours of pain and frustration. They can heat it up while its in the press if they have to while your safely drinking a coffee at a cafe
  5. #6403
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    What has made you Angry Today???
    Noticed a slight oil leak last night on the driveway under the patrol... Over night turned into a puddle. Turns out that the Rear main seal on the engine block is most likely gone and needs replacing. Quotes range from $1000-$1500 from 4 different places!!! Arghh!
  6. #6404
    Hardcore 2TROLLFAM's Avatar
    Nov 2011
    Chuwar - Ipswich - QLD
    My Navarra had the same problem - Brad soaked and beat the beejees outta of it for days before he put the dam thing in the press - even then it took abit but she came out with a bang !!
    NISSANS Rulz .... "Amelia" the 2006 4.2ltr Patrol Ute & "Seamus" the 2008 3ltr Patrol Wagon
  7. The Following User Says Thank You to 2TROLLFAM For This Useful Post:
    Hodge (16th October 2015)
  8. #6405
    Grrrrrrrr....just need to cut sick.............
  9. The Following 2 Users Say Thank You to Avo For This Useful Post:
    Hodge (16th October 2015), Woof (16th October 2015)
  10. #6406
    175 Post(s)
    No good mate, hope you get it sorted before your upcoming trip.
  11. #6407
    465 Post(s)
    Problem is he can't get behind it to press it out. I got a press here he could use. I will come free I reckon, Just needs time to let the Inox or CRC soak in. Good hits on the side with a mash hammer will help break the rust.
  12. #6408
    175 Post(s)
    When the pin holes are lined up,the tongue usually has a bit more room to go in. So I've been hitting it in as much as out and no go . I reckon a press to push it in is the go.
    Sent from my SM-T705Y using Tapatalk
    Mar 2011
    14 Post(s)
    Yeh I'm process of getting a few quotes at the moment, most likely going to get ATOC to get it done. They seem pretty reasonable and competent - plus their vendor thread has good reviews as well. Going to set me back a fair bit still, but thats just because of the labour required to get the transmission out to replace the seal
  14. #6410
    Yo Eric want me to see if Airport West have a decent press .
    If not take it down to Andrew at On-Track
    I wouldnt be tying it to a tree and "gently" tugging it.
    There are unknown forces involved. A whole heap of things could go wrong
    Press it out if you can and live to tell the tale lol
  15. The Following User Says Thank You to threedogs For This Useful Post:
    mudski (16th October 2015)
