7th April 2011, 03:44 PM
#11
scratching my head as to why this was overlooked, everyone got CCA - cold cranking amps, but no mention of RC - reserve capacity which is how many minutes it can deliver 25 amps before falling below 10.5v (or possibly 10.9v, but either way its the usual battery cutoff voltage)
so to convert it to A/hr just quickly, its RCx25/60, so this one is = 140x25/60. or 140x25 = 3500, then divided by 60 you get 58 A/hr.
as someone pointed though, running a non deep cycle battery that low will wreck it pretty quickly. I've used and abused marine combined deep cycle starting batteries for years and wish I had one for my current patrol. They last longer and are more robust to boot.
The Following 2 Users Say Thank You to melts For This Useful Post:
Bigcol (7th April 2011), DX grunt (7th April 2011)
7th April 2011 03:44 PM
7th April 2011, 04:53 PM
#12
Bitumen Burner
Thanks melts.
I bought my truck from a car yard and I'm thinking that they changed the battery. I really don't think Telstra would have put a cranking battery in as the 2nd battery, knowing it has to power lotsa stuff. Think I might have been 'ripped off', but I can't prove it, so I'm up for about $230 for a deep cycle one.
7th April 2011, 04:55 PM
#13
I am he, fear me
melts
Uuuummmm, have to disagree with you on that... your math is OK but the relationship is wrong
There is pretty much no specific correlation between RC and AH rating other than a rule of thumb that the Amp/Hour Capacity of a battery is better than 1/2 the RC or if going the other way the RC is approx 2 times the Amp/Hours.
The actual relationship varies dpending on battery construction and technology IE Wets V AGM V Calcium V Cranker V Marine V all rounder.
The reason being that the way the two "ratings" are determined is different. The rule of thumb I have always used for a wet cranker like Roscoes to get from RC to AH is RC rating divided by 2 add 15... which is how I pulled 85 Amp Hours outa my butt. Not saying its right but that will be close.
Have a quick Google if you wish here is one result From the University of Hawaii...
Many batteries today are rated in CCA or RC. CCA is Cold Cranking Amps. CCA is approximately equal to the RC of a battery times five. [1000 CCA is about 190 RC]. RC is Reserve Capacity. You can convert RC to amp/hours by the following formula:
Amp/Hours = (Reserve Capacity / 2) plus 16
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
7th April 2011, 05:28 PM
#14
I see what you mean, but i've always used my maths with the marine deep cycle units and been happy with it, probably because it gives you a lower value than actual haha
Just wondering why testing RC is pretty well defined as fixed amp draw to volt x to give you a time as RC, as amp-hour is amount of amps y to reach voltage x by fixed time 1hr.
I know that as you draw power from a battery you have a curve to deal with, and batteries have a sweet spot for how much power you can take from them (usually amp-hours is based on a 20 hour draw rate for SLA batteries, for example, and drawing the same amp-hours faster from a SLA can be bad for it, and in some cases impossible)
actually, as interesting my train of thought there was (and why i've left it there) i think its got a lot to do with the nature of the discharge rate, and the RC test is generally harder on batteries than the loads people use on them, so amp-hour gives a better / more optimistic reading of how much power the battery can provide. I tried to find info on discharge rates and was promptly reminded of the curve you see with batteries and lead me to learning about the Peukert effect which explains the difference between amp-hours and RC.
the short of it, you'll only get 100% of your Amp-hours if you use it over 20 hours. you'll get 10% more if you use it over 100 hours, and 10% less if you use it in 8 hours. and so you can get from that you'll get even less using the RC rate, which is roughly around 2hrs for the battery posted.
so silly me i assumed it was linear over time, even though i knew SLAs suffer from the faster you take the less you get syndrome.
The Following User Says Thank You to melts For This Useful Post:
the evil twin (7th April 2011)
7th April 2011, 05:34 PM
#15
SPAMINATOR
7th April 2011, 05:35 PM
#16
I am he, fear me
Gotta agree pretty much 100% with ya there, Melts.
Crankers are easy to suss out as CCA is pretty much God. It is Aux's where all the brainwork comes in. What are they running, how long for, duty cycles yadda yadda yadda... what suits one dude is hopeless for someone else. Is RC of more relevance than Capacity for what the individuals use the battery for.
Oh and Growlers... can't have too small a battery mate... the Beer might get warm. Hehehehe
7th April 2011, 10:08 PM
#17
Travelling Podologist
Ross, have a look here.
I agree with him that the best reference is Collyn River's books. Very easy to read, all the info presented in a friendly manner. I know both Val (website) & Collyn personally & have 3 of Collyn's books.
FWIW - and there are always multiple opinions on batteries, I wouldn't be putting an AGM under the bonnet. It get's pretty hot under there. There are many good reasons for using AGM's but they don't like to get too hot. Stick with a wet battery under the bonnet.
Cuppa
7th April 2011, 10:30 PM
#18
I am he, fear me
DX grunt
Thanks melts.
Cuppa
Cuppa
Thats an NRMA (NSW) Roadside assist Battery they would have had lying around or whatever so don't read too much into it.
I totally agree with Cuppa... AGM's and hot engine bays are not an ideal mix. I would go an All Rounder or similar.
I am spec'ing up some Solar Powered Data Collection sites for work ATM and chatting to another engineer today (seems Thursday is Battery Day) who reckons the vast majority of sealed batteries die an early death because of electrolyte issues.
He was of the opinion that for general Automotive use good old open Wet Cells which you can check the levels and replenish electrolyte will last significantly longer than sealed valve regulated jobbies that all seem to fail 1 or 2 days after the warranty runs out.
8th April 2011, 04:10 AM
#19
DX grunt
Thanks melts.
just purchaced one from local dealer i asked if he had any scratched ones or lables had fallen off /yes was the reply and only cost $150 instead of $230
OH LEATHER IS NICE
The Following User Says Thank You to my third 256 For This Useful Post:
DX grunt (8th April 2011)
