15th February 2015, 07:56 AM
Best airbox for gu tb45
Hi guys. I remember seeing a thread but can't seem to find it. (Might be on different forum).
Im after ideas on changing the barrel airbox on a gu tb45 to something possibly smaller and cheaper to replace from another model. The curent filter is $99.
Also im starting to run out of room for under bonnet space.
15th February 2015 07:56 AM
15th February 2015, 08:07 AM
After searching around. The zd30 seems to be the go.
15th February 2015, 09:49 AM
Hardcore
I'm interested in this also although i should mention you can get genuine filters from patrolapart for $63
Lucus30's 1999 GU ST TB45E
15th February 2015, 12:18 PM
You can get a washable Unifilter for the TB45E for $75.
If you want to see a TD42 airbox in a TB45E check my turbo build thread.
John
15th February 2015, 01:58 PM
Is there much difference between the zd30 and td42 airbox
15th February 2015, 02:52 PM
mjr350
Maybe in the lid but you have to modify that anyway. I believe they use the same filter element and bolt in the same way.
The holes are already there.
Btw, I feel absolutely no difference in performance with the modified TD42 airbox.
John
15th February 2015, 05:18 PM
Thanks for that. I'm not after a performance gain. Just a little under bonnet real estate gain.
15th February 2015, 05:55 PM
#8
Sorry, my comment wasn't clear. I meant it to say that there's no performance loss in changing the air boxes.
It was suggested on another forum that the TB45E airbox was better than the TD42 but I don't feel it..
John
15th February 2015, 09:06 PM
#9
jff45
Fair enough. Bigger is probably better but I don't care. I need some room for a fuse block and solar regulator
