31st January 2015, 12:59 PM
#41
Thanks Bacho86, Thanks for putting your pics up too mate, without those i wasnt sure if it would hold, pics make it heaps easier than trying to rest it, hopin out from underneath for a look. Save heaps of muckin around.
Appreciated.
I emailed Runva thismorning about 1am ish and got a reply at 7 am, hows that for customer service. Anyway advice was to change the wired remote leads around, rather than doing that i simply pulled it apart, turned the switch around and all works fine, took 5 minutes.
Thanks to everyone for their help.
Lifes a journey not a destination.
The Following User Says Thank You to Smoothrun For This Useful Post:
Bacho86 (31st January 2015)
31st January 2015 12:59 PM
31st January 2015, 01:02 PM
#42
catchinjack
Seen a post elsewhere that the Runva 11xp is selling for $600 which includes free install as well from Shents Automotive at North Wyong NSW. Not a bad deal really.
Thats a bargain I recon.
31st January 2015, 08:08 PM
#43
Smoothrun
Appreciated.
Good to hear they got back to you so quickly and you were able to sort it all out
7th February 2015, 09:10 AM
#44
Thanks for the pictures and explanations guys. Helped heaps during my install.
I wanted a semi stealth install but also wanted the control box to be accessible. So following on from the ideas I saw here and similar to someone else's install, I got a 1m length of 3mm steel, ran the each side of the bull bar above the winch. Knocked out the control box blank in the bar, and mounted the control box on the steel with just the wired control input poking through the cut out in the bullbar. Took me waay longer than it should have but happy with the end result.
Thanks for all the help.
Rej
7th February 2015, 12:54 PM
#45
Patrol Guru
Sounds like a sweet install. Pics or it didn't happen
Cheers Rod
My Build 2005 TD42TI
7th February 2015, 07:30 PM
#46
The Following 2 Users Say Thank You to Richie-Rich For This Useful Post:
Rocket55 (7th February 2015), sharpy007 (10th January 2017)
7th February 2015, 10:07 PM
#47
Richie-Rich
Rej
I should have mentioned that i can still access the panel from either top with bonnet open or fro. The front rhs of the winch through the bbar. Nice job Rej. Appreciate the pics . Following pic shows the space available.20150131_094054.jpg
8th February 2015, 11:18 AM
#48
Nice work Richie-rich, certainly a nice install! Just shows that there are many different ways to get the job done, unfortunately i wasn't able to to use the factory cut out on the bar because I have a light bar running across there, but yours looks very stealth
8th February 2015, 06:29 PM
#49
Thanks guys!! I am happy with how it all worked out.
Massive thanks to this forum for all the ideas.
I must have worked out a 100 different spots but something would always foul or not work.
My plans will be 2 rounds LED spotties and then between a clearance cam mounted in the middle. The control box placement should allow for this. Then a curved LED bar on the rack and I no longer have to be scared of the boogie man...
Rej
8th February 2015, 11:51 PM
#50
This forums what its all about Rej. Ive had heaps of help in the past and those who contributed makes it all worth the while. Congrats on a great job. And put up some pics when ya got it all done.
Cheers Dave
