9th November 2014, 03:35 PM
Smart like tractor
Turbo work.
Gday.
I have been modifing my turbo while the motor is out. Started with the turbine housing. I removed alot of material and also opened the wastegate from 19mm to 26mm
Before
Wastegate port
After
96 GQ coil/Cab
08 G6eT
![](image.php?s=0f18cf192aa46756034a06a20aa027dc&u=1281&type=sigpic&dateline=1483248064)
The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
AB (9th November 2014), Alitis007 (9th November 2014), Sherro (9th November 2014)
9th November 2014 03:35 PM
9th November 2014, 05:50 PM
Patrol Guru
what do you use for new Wastegate flap?
gotta do this to my xr6t as I put exhaust on and now it overboosts. port n enlarge the port will stop it
Great work mate looks very tidy!
What dremel did you use Bene?? Can you post a pic
9th November 2014, 06:12 PM
Smart like tractor
matfew
Yeah I heard that it an issue with the xr6t's, my wastegate flap still covers the port
Alitis007
A makita die grinder, then a dremel branded dremelwith a grinding stone then a 180 grit and 320 grit abrasive buff
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
9th November 2014, 06:22 PM
Sorry I meant to say tge bit, cheers for that! What do you expect to gain from this???
Hardcore
Are we going to see 40psi? Shot gun a ride in this beast again and do little red again ha that was fun
Such is the rule of honour.
9th November 2014, 08:25 PM
Smart like tractor
Nah no more boost, 'ill just keep it where it is for now then change it after seeing what kind of drive pressures I'll see with these mods
96 GQ coil/Cab
08 G6eT
9th November 2014, 10:09 PM
#8
Hardcore
How come one of the long sides is not square benny ? , is that port matched to the manifold and you will make your own gasket ,or did you just go a bit wide, only ask as from the first pic the gasket internal long edge looks parallel on both sides ?, tis a nice finish anyway bud.
9th November 2014, 11:13 PM
#9
Smart like tractor
I went wide on the exhaust manifold. I painted and took the pic before double checking. Its all matched now
96 GQ coil/Cab
08 G6eT
04OFF (11th November 2014)
9th November 2014, 11:19 PM
#10
matfew
I have seen people use old valves from a cylinder head for this.
