20th August 2014, 02:04 PM
How good are your problem solving skills?
Ok folks,
ill outline the problem, lets see if you can diagnose and have a solution. Vehicle is a 1988 GQ Wagon TB42S. Problem is no spark coming out of Distributor on 1 & 4..
New Coil, Capacitor, Condensor, points, Separator Plate, Rotor & Cap. Leads & plugs under 3 months old. Vehicle started missing on way home last Friday and havent been able to get it to run right since. Definately no spark out of cap from 1 & 4...
Any Ideas?
20th August 2014 02:04 PM
20th August 2014, 02:08 PM
Has the dizzy moved in any way, could have put the timing out if so. Sent from me using Forum Runner
Live life, Love life.
Snatch straps on towballs can harm and/or kill!!!!!!
20th August 2014, 03:23 PM
Firing order 153624 so 1+4 are sequential check for a crack in the cap from being dropped maybe or that everything is sitting square with the same clearances .Apart from that I am absolutely no help as I love the smell of soot and diesel but a petrol guru will surface shortly I'm sure.
20th August 2014, 03:54 PM
has got me absolutely bamboosled - and broke! I have replaced all the things one would think would cause this, i havent pulled the dizzy out yet, rather trying the think logical approach before resorting to total disassembly..
going away from electrical for one moment - apart from the points totally missing the lobes on the dizzy 4 & 1 on its rotation, what else would, could or is possible for it (mechanicaaly) to fail?
20th August 2014, 03:57 PM
Any play in the dizzy shaft?
20th August 2014, 06:02 PM
well the vehicle is now in "the shop" trying to find a solution, and it has the sparky a bit perplexed as well, but has told me that the shafts on these things were suspect from new, and only takes a bit of play for it to do this - well I am hoping that this may be the cause. measurements will happen tomorrow and a cause found, sounds like solution may be to ditch the points completely??
20th August 2014, 06:14 PM
Check at night with the lights out, spark plug caps could be shorting,
condenser could be breaking down also,
Do one thing at a time.
Didn't these early petrols have an extended rotor button as an option???
20th August 2014, 07:35 PM
#8
seeing as you have replaced everything except the leads and plugs even though they are 3 months old you may have a crook lead or the plugs maybe the problem. but it does seem odd that its on 1-4 and the problem I feel will be in the cap or rotor area. even from new these parts can have issues
21st August 2014, 03:43 PM
#9
OK Folks, the Cause. A shaft on the Dizzy that has too much play and was pulling away from 4 & 1, so Mudski, you win the prize. Thanks all
The Following 4 Users Say Thank You to Gordy For This Useful Post:
Avo (21st August 2014), dads tractor (22nd August 2014), jack (21st August 2014), mudski (21st August 2014)
21st August 2014, 06:15 PM
#10
Gordy
Boohyeah!!!!
