29th June 2014, 01:45 PM
#761
Last couple of days my clutch pedal has felt very firm when accelerating but soft while backing off and changing down... now I know these are vacuum assisted and George said that is normal for a car that has a cam but it is steadily getting worse.... George is in the mountains today collecting firewood so I cant hassle him...he he.
It feels like it is resisting me but as I back off it feels so easy to push the pedal..??
Its had a new slave put in nearly 2 years ago and the fluid level seems fine....
29th June 2014 01:45 PM
29th June 2014, 01:53 PM
#762
The Following 3 Users Say Thank You to growler2058 For This Useful Post:
Ben-e-boy (29th June 2014), cgm (29th June 2014), Clunk (29th June 2014)
29th June 2014, 01:54 PM
#763
growler2058
What can I say
Shoulda got a LoKKa!
WANKER !!!!!!!!!!!!!!
Just had a look at the fluid and it looks like it could do with being flushed as it is very murky...?
The Following User Says Thank You to Bloodyaussie For This Useful Post:
growler2058 (29th June 2014)
29th June 2014, 03:27 PM
#764
Smart like tractor
That is going to be normal because with a cammed motor you will have a lower manifold vacuum.
Install a vacuum gauge in your patrol, and you can monitor your engine.
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
Bloodyaussie (29th June 2014)
29th June 2014, 03:44 PM
#765
Ben-e-boy
Thanks sweety !!!!!!!!!
30th June 2014, 03:14 PM
#766
30th June 2014, 03:52 PM
#767
I have a vacuum leak and am just about to go and find it... it is getting worse.
Will report back.
30th June 2014, 04:29 PM
#768
Looks like its the booster..... bugger !!!!
Who sells kits... found one mob but they are out of stock.
30th June 2014, 06:37 PM
#769
Dont worry I found a kit from Patrolapart for $61.....
On a side note found a GQ td42 suits cab swap or use for the running gear........ Hmmm ????
30th June 2014, 10:41 PM
#770
as far as the 98 goes i never noticed any gain running 98 vs regular 91 until i added a bit more timing which made it ping on 91 if i put any sort of load on it.
