5th May 2014, 06:31 PM
#3591
Added some LEDs to my rear door table
5th May 2014 06:31 PM
5th May 2014, 06:32 PM
#3592
Patrol-Guy
How hard is it to convert tail lights to LEDs?
I got a loom from the rear of a falcon sedan and put led globes in them. Used a hole saw to make the hole then used a semi round file to just make it fit.. Was pretty easy then wired it in from the lights in the bar..
The Following User Says Thank You to Dave_GU_ACT For This Useful Post:
Patrol-Guy (5th May 2014)
5th May 2014, 06:33 PM
#3593
threedogs
68 led T20 will fit in the front parkers make for very bright DRL to.
Yep on order from brightlight auto. I only use them. Even though they are a little on the dear side, their lights are very good as the Chinese ones aren't very bright.. When it's dark I'll take a few snap shots.
5th May 2014, 07:24 PM
#3594
chrisc2306
You can buy bayonet led bulbs that just fit in place of the standard ones
Thanks, is there a need for resistors?
5th May 2014, 08:31 PM
#3595
Hit limp mode for the first time ever! 19psi in third gear..
5th May 2014, 08:55 PM
#3596
Patrol-Guy
Nope no need for resistors just replace the standard ones with led style ones and away you go. This is the ones I got obviously they are 24v because I have a safari but you can get 12v ones too
http://www.ebay.com.au/itm/221423169...84.m1423.l2649
The Following User Says Thank You to chrisc2306 For This Useful Post:
5th May 2014, 09:13 PM
#3597
Refitted the BMS head unit
While I had the ceiling down I decided to relocate the Redarc BMS head unit to the overhead console. Routed the head unit cable up the B Pillar and across the roof.
![](http://i935.photobucket.com/albums/ad197/BenKDJ/IMG_20140505_192804_940_zpsybjr4q6x.jpg)
![](http://i935.photobucket.com/albums/ad197/BenKDJ/IMG_20140505_193216_067_zpsngsejhav.jpg)
6th May 2014, 04:33 AM
#3598
Tracing the feared 24v to 12v converter wires! :O they are all cut....
6th May 2014, 08:24 AM
#3599
Replaced the front 31-10.5x15 tyres
6th May 2014, 09:53 AM
#3600
BenK
How did you go removing the roof lining from the front window rubber??
