5th May 2014, 12:12 PM
Engine Stalling on Gas after Fitting Snorkel
Hi Guys,
I have recently fitted a snorkel to my 92 Patrol, it runs great on Petrol but stalls alot when I run it on Gas. I did a quick search on google n found a page where the guy tried few things, then turned the head on the snorkel so it faces the rear to reduce the cold air forcing in and stalling the engine. I did this and it doesn't stall as often but still does it. Any ideas?
cheers
5th May 2014 12:12 PM
5th May 2014, 12:26 PM
Hardcore
Hendo70
Hi Guys,
cheers
You need to fit a balance pipe between your airbox and the mixer
Lucus30's 1999 GU ST TB45E
The Following 2 Users Say Thank You to lucus30 For This Useful Post:
Alitis007 (5th May 2014), Hendo70 (5th May 2014)
5th May 2014, 12:31 PM
X 2 with Lucas you'll need a balance pipe
The Following 2 Users Say Thank You to threedogs For This Useful Post:
5th May 2014, 12:33 PM
threedogs
cheers, is it an easy process or do I need to get it done?
5th May 2014, 01:50 PM
Hardcore
Personally I have never done it but if you search for Patrol balance pipe you find will find your answer. Also you probably should get your gas tuned after a fitting snorkel and balance pipe
Edit: Have a look at this thread among many others
http://www.nissanpatrol.com.au/forum...l=1#post424259
or this one
http://www.nissanpatrol.com.au/forum...l=1#post232145
The Following User Says Thank You to lucus30 For This Useful Post:
5th May 2014, 06:26 PM
Until then try spinning the head of the snorkel the other way.
IMO and should be taken with a grain of salt.
The Following User Says Thank You to Parksy For This Useful Post:
5th May 2014, 08:10 PM
Parksy
Yeh did that but found was only ok for short trips around town, once I drive for any further she stalls when I slow down or come to a stop. I have an elbow pipe fitting at the back of my Mixer which has nothing attached, is this the point I run my pipe to from the airbox?
