30th January 2014, 10:38 PM
Bad Noises. Front End, maybe Auto Hubs
Well I got a tricky one. I'm guessing it's probably the auto hub, but thought I'd ask if anyone else has had the problem.
It's a grinding rattling noise coming from what sounds like the right front wheel.
If I take off from a stop and drive for some time it will just kick in and start making this noise, now when I slow down to nearly a stop once hearing the noise the car makes a clunk and you can feel the clunk up through the drive line. This has been going on for some months, and doesn't happen every drive, say 2wice a week when driving to work and back mon -Friday, sometimes more often. Even if I haven't. Haven't Used 4x4 for days and it'll still do it.
I can't afford to take the car off the road yet as it's my only ride for now.
1998 GU - RD28t > TJM Bull Bar > Dual Batteries > Boost & EGT Gauges > Turbo Timer > Minor Engine Mod's.
30th January 2014 10:38 PM
30th January 2014, 11:07 PM
I am he, fear me
Lock the front hub and see if it stops.
Driving around with the hub locked won't hurt anything as long as you don't engage 4WD
Could be a CV or something else but more often than not it's a hub asking to be serviced
Could be cv joint which you can hear clicking when turning. Mine did the same when I bought it and ended up being the auto hubs trying to lock. I removed the auto mechanism from the hubs and all good.
Cheers 4by
Can I put a Holden badge on my Chevy ?
31st January 2014, 06:52 AM
Right-O will leave the hubs in lock and see what happens.
I'm guessing if this fixes the problem I'll need new hubs, I'd imagine they would wear out fairly quick driving my average 200km a week.
31st January 2014, 07:09 AM
Shaunous
Na just remove the auto mechanism. Just means you'll have a free or lock hub, not auto or lock..
31st January 2014, 08:45 AM
Yeah as westy said just remove the auto locking section from the hubs. Do a search on this forum and youll find some info how to do it.
Cheers 4by
2nd February 2014, 09:23 PM
Thanks lads, this week will be the true test to determine the problem. Will comment back on results.
