Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 78
Thread: twin e locker install
  1. #61
    Dec 2012
    i made this tool up to set the back lash
    set you dial indicator up like so (i acually did this on the coast and drive side but alot of ppl just to it on the drive side)
    you adjust the back lash by scewing the carrier bearing adjuster side to side to move the crown wheel (or ring gear) closer to or further away from the pinion gear
    ill take a pic of the pinion gear in a sec and put it up so folks can see what it is.
    dont forget that once you have set the back lash you also need to load the carrier bearing up (called preload .... your tighten the carrier bearing adjusters so there is load on the carrier bearing and they are tight up in their races)
  2. The Following User Says Thank You to gqmoder For This Useful Post:
    BigRAWesty (21st January 2014)
    Dec 2012
    pinion gear
  5. #63
    Dec 2012
    almost got the front all put back together. have to stop soon i gotta goto the gym in a couple hours and i still have to plug laptop into my ss before i go out. i was driving down belconnen road the other day (in canberra) and the bloody thing started running real ruff then stalled right in the damn left hand lane i had to get out and push it of the road like a loser.
    people were behind me and everything and im pushing my ss to the side of the road damn thing (nice word)
    i think i might of got a bad dose of fuel from the woolies servo.
    dont ever want that happening to me again was damn embarrassing.
    anyway i have to run it up on efi live (program that talks to the pcm (onboard computer)) and pull the error codes and see what happened
  6. #64
    Dec 2012
    looks like i'm up for a crank angle sensor
  7. #65
    Dec 2012
    looking sexy
    wanna get this back together tonight.
    got a job starting tomorrow and wanna get motor in this weekend.
    got friends wanna come over not this weekend but next to see this motor start for the first time.
    of to gym then back into it
  8. #66
    Expert twase's Avatar
    Campbelltown NSW
    Good work, btw I consider a clean bench if I can see enough of the bench top for the job at hand. Any more is a waste of working time. You should have a crank sensor from the stuffed motor shouldn't you? This should get me subscribed to this thread.
    1990 Ford Maverick LWB - BA XR6T powered.
  9. #67
    Dec 2012
    yeah i have a crank sensr from that dodgey motor i bought but dont really wanna put anything from that in my ss
  10. #68
    Dec 2012
    hi all work got busy and truck come to a hold just putting rear disc and wheels on now then finishing plumbing fuel system and putting motor back in tomorrow to get ready to start for the first time ... really getting close now. this project has taken me years now i started off buying a ls1 motor from from guy in sydney and get ripped off with a dodgey motor but thats ok cause now i have a 6.2!!!! nno 5.7. anyway get these discs on fuel systems and evap systems hooked up
  11. The Following User Says Thank You to gqmoder For This Useful Post:
    Stropp (22nd February 2014)
  12. #69
    Dec 2012
    sorry i got abit less descriptive towards the nd of the locker project time became a huge factor. if you do it and are unsure on anything always just message and ill help.
    make sure you clean ya disc with emery papper and brake cleaner before you fit them
  13. The Following User Says Thank You to gqmoder For This Useful Post:
  14. #70
    Patrol God Stropp's Avatar
    31 Post(s)
    good write up mate thanks.
