Results 1 to 10 of 17
Thread: Ironman Bullbar on a GQ
    Sep 2010
    Mandurah, WA
    Hi,
    I recently had my alloy bullbar replaced with an ironman protector (BBT010) bullbar.
    After i had the bar installed the factory/aftermarket recovery points on the chassis are covered by the bottom of the bullbar and protector plate. The bar it self does not have recovery attachment points.
    I have contacted Ironman to discusses and see if they had a solution. There response was they never head of any other issues like mine and they don't design their bars to attach recovery points, Just winches.
    Has anyone had similar issues with Ironman bars and found a solution ?
    Matt
    any chance you can throw up some photos so we can see how its mounted
    Oct 2011
    Essendon
    X2 with photos.
    Pretty crappy response from Ironman if that is what they said. Perhaps they recommend towball recoveries too....
    Interested to see pics of inside /outside mounting points,
    I'm sure there is a solution
    BigRAWesty (9th November 2013)
    Expert janderson's Avatar
    Bearii Vic
    I've got a Ironman front bar on my GU. It also dose not have recovery points. I've fitted 2 of threedogs ones
    1st G60 Then MQ Now GU
  7. The Following User Says Thank You to janderson For This Useful Post:
    threedogs (10th November 2013)
    Perth WA
    63 Post(s)
    Hey mate, I would never do any recoveries by using a bull bar, get yourself some rated recovery points
  9. The Following User Says Thank You to Woof For This Useful Post:
    Avo (10th November 2013)
  10. #7
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Doggy View Post
    X2 get some recovery points the patrol has holes on the chassis ready to go
  11. #8
    Should have the OE hook still there on the drivers side or even if removed the 3 captive nuts should be there.
    cant remember seeing any bar fitted on a GQ using those bolt holes
  12. The Following User Says Thank You to threedogs For This Useful Post:
    Clunk (10th November 2013)
  13. #9
    Mine fits directly to those holes but still able to fit the plates there aswell, just need longer bolts........ Which I still don't have on the drivers side.
  14. The Following User Says Thank You to Clunk For This Useful Post:
  15. #10
    Sep 2010
    Mandurah, WA
    Hi,
    Thanks for the reply's. i am not trying to recover my 4wd from a bullbar recovery point, the issue i face is that the Bull bar covers the chassis mount recovery points.
    You can just see the Tow/Recovery hitch through the high lift jack point on the bar.
    I can remove the stone plate, though if i use the recovery point with the strap under the bullbar, it will jerk the bar upwards every time i use it as a recovery point.
    I am aware that this is a TOW point, i have not installed the rated recovery point yet.
    Matt
