Results 1 to 10 of 12
Thread: Setting up an air tank, need advice
    Advanced brw1994's Avatar
    Nov 2012
    Hey guys turning my rock sliders into an Air tank hopefully will have a decent capacity on the too being 65mm tube.
    What is required for this to happen, I have a thumper air compressor 160/L p/min which will be hard wired in then I will run a line from this to a 'T' piece under the cab where it will divert into each slider.
    What is required to get the compressor to cut off at a certain Psi and what Psi would you recommend? I assume I need a pressure switch and if so where in the system does it fit in/how is it wired in? If there is anything else you suggest I do please let me know
    You need a 100psi pressure switch ,a manifold with a one way valve to hold pressure.
    Pics are what you may need no pic of pressure switch
    I use these for diff breather kits but you can go up to 10 mm IYL
    How are you pressure testing sliders ?
    Also you may want to have F/R air outlets
    Think I have pic right but someone will correct it I'm sure
    Some use and low cut off,
    43 Post(s)
    Not to put you off but I don't like the idea as to me it makes it more venerable to rupture and failure.
    Think of a flat balloon. Take a fork to a flat balloon, pretty boring as bat shit. Sure might put a whole in it but nothing happens.. Now blow it up and take a for to it.. And Im pretty sure I read that the average balloon is sub 1psi above atmosphere.. Now you wanna put 100psi into steel..
    Just food for thought.
    Owner of
    Westy's Accessories
    Nov 2012
    Yo TD thanks for that mate makes things a lot easier for me but the pressure switches I have seen have 2 males connectors on the end for 12v female connectors.. I'll have another look.
    I understand where you are coming from westy but I built the sliders from 65od 5m thick steel steam pipe I don't see it failing me and it was welded togther with an arc for better penetration if you still feel this wont work let me know
  6. The Following User Says Thank You to brw1994 For This Useful Post:
    BigRAWesty (24th July 2013)
    G.day, brw1994. Another problem would be moisture build up in the rocksliders. It could cause them to rust from the inside out. As for welding them without "pressure vessel certification', I doubt whether insurance would cover you if something went wrong.
  8. The Following User Says Thank You to mudnut For This Useful Post:
    brw1994 (31st July 2013)
  9. #6
    43 Post(s)
    Quote Originally Posted by brw1994 View Post
    It'll work, for sure. But just use caution if they get dinged up.
    Owner of
    Westy's Accessories
    Legendary happygu's Avatar
    Get them zinc coated or gal dipped to prevent moisture from rusting them out from the inside ( it would take a while for it to rust out anyway due to the wall thickness of the steel, but it is better to do it right first up, and then they will last ).
    Mic
  11. #8
    Thomastown, Melbourne
    6 Post(s)
    This is a basic drawing (I cant find the drawing of the relay set up) sent to me from 04off....
  12. #9
    Expert Blownlc's Avatar
    Werribee Vic
    I wouldn't be too worried about the repercussions of a rupture or the event of one. When pressure testing fridge pipes (410a) they are pumped up to 2500kpa/ 325psi (roughly). I know that if I take a happy gilmore run up and hit it with a hammer, it won't rupture.
    Obviously the copper will dent a flatten due to its malleability, wild steel will do the same when you drop 2.5tonne on it.
    My two cents spent : )
    LESS YAP YAP, MORE TAP TAP!!
    http://www.nissanpatrol.com.au/forums/image.php?type=sigpic&userid=8495&dateline=1347611  053
  13. #10
    Nov 2012
    Thanks for all the replies fellas, as for insurance I am bomb isnured so not stressed about that, the rusting issue was one I had already thought about and I was thinking of tipping some Killrust primer in their giving it the old swirl around and letting it sit to dry for a few days to give it a fighting chance and appreciate the diagram!
