22nd July 2013, 09:43 PM
Runva 9,500 Comp winch or 12,000lb Standard?
Just a bit lost on which winch I want to go to, was not overly happy with my Warn XD9000 recently and wanted a 12,000lb winch so I am selling the Warn but not sure if I want the 9,500lb Comp winch from Runva with a potential 10HP + or their Standard 12,000lb. I was leaning towards the 12k but 110:1 Sounds yumm as does 10.7HP ![Bowdown](images/smilies/bowdown.gif)
http://www.ebay.com.au/itm/Runva-4x4...33cf135&_uhb=1
http://www.ebay.com.au/itm/Runva-4x4...3c953ad&_uhb=1
22nd July 2013 09:43 PM
23rd July 2013, 12:15 AM
BIG & BALD
I think I will be going with the 12000lb rope winch.
Are you planning on wiring it up using 24v to get the 10+ horses out if the motor on the 9500lb comp winch.
23rd July 2013, 01:11 AM
Yeh I'll go a triple battery system which was always my plan, run 2 crankers in series in the engine bay then a 12v to 12v charger will be set up in the rear to a deep cycle hidden under my drawer system (Saves running massive cables from front to rear) But I am thinking the Comp winch.. I mean it has more pull than a Warn Hi mount, more than 2x as much horsepower slightly lower line rate But 3x Cheaper and I have watched videos of it genuinely being used it comps since I posted this which really pushes me towards the comp winch.. Love my current Warn but its hectic slow 230:1 or something like that
23rd July 2013, 01:35 AM
Moderator
brw1994
But how are you Sorting your 24v?
Are you running a second Alternator to charge 24v? and isolate 2 of those batteries for your Winch only? Sorry maybe i read your description wrong?
![Cool](images/smilies/cool.png)
Check out my Toy -->
Rogue Dung Beetle
23rd July 2013, 05:41 PM
BIG & BALD
I picked up the EWX12000 rope winch for $650 with free delivery from Tough4x4.
23rd July 2013, 07:18 PM
Yeh I don't know yet I know I'd have to run 2 alternators but I guess if I get the comp winch I'll see how it goes first.. however knowing me I'll want the 24v's because the grass is always greener on the other side haha
23rd July 2013, 07:57 PM
Moderator
brw1994
If your keen on the 24v then you will need a 24v system on the car. If your happy to run 3 batteries (which you will need to) then leave the cranking battery in the engine bay for 12v and then fit a second alternator to charge your 24v system.
Run the cable into the back where your 2 batteries are setup for 24v and then run that back to the winch. If you want to run other accessories off those batteries then buy a 24v to 12v inverter.
Be aware though if you run a 12v winch motor on 24v it will be wicked! But! Winching out will not be good for the motor and you will burn it out quickly. Free spool it your friend. Or hook up a second solenoid to he winch motor and winch out via 12v
Winch in will be Awesome though! Running 24v through a 12v motor is a Massive upgrade over running a 24v motor.
You should see a HiMount 6hp running 24v through it! Holy Sh1t! On my list of future mods. Just bought the welder, own enough 70mm wire to run to the back, just need the time and an alternator now! Will be Sick!
Hope that helps some
Rogue Dung Beetle
31st July 2013, 12:46 AM
#8
Ended up picking up a 2nd hand high mount for $500 last week got a new 4.6hp motor bottom end seals brake rebuild kit total cost $1200 fully rebuilt with breather lines Oil fill and drain plugs etc stoked!
31st July 2013, 09:59 AM
#9
Moderator
brw1994
good stuff mate, there are a few mods to do to them to make em tuff. Pin hte free spool is a certainty if its not done already and easy for you to do yourself mate.
Rogue Dung Beetle
28th July 2015, 02:27 PM
#10
Sorry to bother Mego, but is that into a standard Nissan winch bar?
Was told that there is an issue getting a 12000 in as it needs some rework near the chassis. Definitely the one i want, but worried about the hassle if any.
Any help appreciated.
AJTich
2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
![Xxxx](images/smilies/xxxx.gif)
"I don't get bogged, I have unplanned 4WD training activities..."
