25th March 2013, 06:17 PM
Is my GU 4.2 n/a too old for turbo!!??
Hi lads,
I know this topic has been touched on before but, I just got off the phone to a well recommend deisel workshop in Perth, was told that they would not fit dts turbo kit to a 98 GU 4.2 na engine with 350,000 kms, as is already a weak engine, but then speaking others they say it's stronger!
The engine has been looked after and in my books is in a good condition!
Any thoughts or other recommendations would be greatful as I was really looking forward to getting some more go outta the old girl and am now slightly gutted!
25th March 2013 06:17 PM
25th March 2013, 06:24 PM
I would be checking the compression and is that's ok, Go for it.
Don't run over 8-10 psi
Quite a few guys have done it and not had any problems.
I am putting one in on my 2000 NA. In 2 weeks and its done 269,000km
Just using stock ht18 turbo and patrol parts.
The Following User Says Thank You to Dam355 For This Useful Post:
abbo_05 (25th March 2013)
Hardcore
I'd do it keep it lowsh boost but if you had the cash give it a little freshen up then boost it
Such is the rule of honour.
25th March 2013, 06:26 PM
Re: Is my GU 4.2 n/a too old for turbo!!??
Doesnt Berima diesels have a 4,2 GQ as their show car? They use it in the 4wd tv shows. It was turbo ed after 350k im pretty sure.
Sent from my GT-S7500T using Tapatalk 2
25th March 2013, 07:28 PM
Moderator
My GQ was turbo'd at 350,000 and is running 15psi and 4.6 gears pushing 35s and Loving it!
Get a compression test if your really concerned but you will love the power up!!
Check out my Toy -->
Rogue Dung Beetle
30th March 2013, 02:28 PM
MudRunnerTD
I agree with MudRunnerTD, also if you have not already done so, replace your clutch! A new turbo will certainly fark an old clutch very quickly.
PS, remember the old adage, do it once, do it right!
Regards,
RLI
The halls been rented the bands been paid, time to see you dance!
13th April 2013, 04:08 PM
Berrima Diesel used to have a brochure that was basically entitled you're car is never too old to have a turbo. Might be worthwhile getting them on the phone and having a chat to them about WHY. The brochure used to say WHY, but I threw it away years ago.
Brian.
13th April 2013, 04:15 PM
#8
Too old to turbo, too old for Viagra never lol IMO
16th April 2013, 12:06 PM
#9
never too old.. Strap a snail on and whistle away..
16th April 2013, 12:47 PM
#10
G’day abbo05,
1. I would get a compression test done first. If the compression's on all cylinders are fine, i would then,
2. Get a full service, change engine oil, oil filters, fuel filter and air-filter and most importantly get your tappets adjusted.
3. In preparation for the new turbo to be installed, replace the old clutch with an h/duty clutch kit and also replace the rear main seal with the gear-box removed.
4. Run boost pressures between 12 and 16psi; also fit the following gauges as a safety precaution for the engine; Boost, EGT and a Water temp gauge.
5. Remember the old adage “Forewarned is forearmed.”(which means that if you know about something before it happens, you can be prepared for it)
I would seek advice from either Berrima diesel in NSW and there contact details are;
Phone: (02) 4877 1256
Email: info@berrimadiesel.com
Address: 3483 Old Hume HWY Berrima NSW Australia 2577
Opening Hour: Monday-Friday 8:00AM-5:00PM(AEST
Or from United Fuel Injections in WA there contact details are;
Phone: (08) 9259 3033
Free call: 1800 199 701
www.unitedfuel.com.au
Address: 479 Great Eastern Highway Redcliffe WA 6104
PS, i hope this info will help you!
Regards,
RLI
