11th April 2013, 10:00 AM
Left blinker blinking fast
Hi guys,
Yesterday my left hand side blinker in my 2007 GU started blinking a lot faster than usual. The right side works normally, and both flash normally with the hazards on.
Any ideas what might be causing this?
Thanks,
Jaycee
11th April 2013 10:00 AM
11th April 2013, 10:09 AM
check for a blown globe and also check for a loose wire in the trailer plug if you have one
11th April 2013, 12:13 PM
pearcey
Thanks Pearcey, will do. I had a rear bar installed last week, so i'm thinking they may have accidentally pulled a wire or something. Could just be a coincidence though.
11th April 2013, 12:51 PM
Does the rear bar have LED lights fitted?
If so and there are no blown bulbs for the LHS indicators you will either need to fit a load resistor to the indicators or replace the flash relay with an LED compatible one.
The Following User Says Thank You to Yendor For This Useful Post:
rusty_nail (11th September 2013)
11th April 2013, 01:04 PM
Or maybe an earthing problem?
13th April 2013, 04:30 PM
It could also be the relay on it's way out. Relays are known to flash faster than normal when they are about to give up and die.
6th September 2013, 02:48 AM
You did check if none of the left hand blinkers failed? Quick blinking would normally indicate a bulb lost in the chain.
11th September 2013, 10:36 PM
#8
Sounds like a globe or flasher relay is gone mate.
11th September 2013, 10:46 PM
#9
Yendor
Wouldn't that make left and right flash at the same rate as the bar would have the same indicators left and right
